323 BG sedan EDM worklog
    You did.
    That's awesome. I'll have to look for those speakers.
    1990 Protege 4WD
    1 3 5
    2 4 R
      Swaybar bushings update:
      authentic mazda's rubber and local made metal elements
      Frame bushings:
      End links set:
      Comparing photo:
      Before installation:
      Almost installed:
      All is OK:
      Frame bushings install without removing inner tie rod of steering rack is almost impossible
      1990 323s BG 1.6i
        Free breathing is very important for us and our BGs
        New air filter was replaced recently:
        After installation , it added nearly +20 hp, lol
        1990 323s BG 1.6i
          Little UPD:
          During the revision of reverse light switch, I've noticed a crack on the left outer CV joint boot. AFAIK it isn't good conditions for CV joint "labour".
          So, some spareparts are F024-22-530 , or Maruichi G55000 (G5500MR) boot kit
          This is his japanese colleague HDK C8002
          And inner boot kits:
          Tool:
          Grease:
          left - for inner, right - for outer joint.
          Removing ball joint
          and tie rod:
          Inner joint seal is here:
          Where is left shaft?
          Here we can see tasty caramel filling!
          we need to clean and wash our stuff:
          Boots are on the joints! They are very flexible - it is very important for their long life. "Plastic" ones don't like winter's temperature.
          Our brave shaft and new boots are on their place!
          It's a shame, but that oil leakages are from disty O-ring... I promise change it, my dear BG
          1990 323s BG 1.6i
            And a little bit photos of front suspension update...
            Front LCA bushing:
            Rear LCA bushing:
            Ball joint from Korean aftermarket producer:
            Ball joint bolt is in the nice state )):
            Right LCA has been detached:
            Xchange:
            I like BG suspension - ball joint is bolt mounting, without auxiliary tools like press etc:
            And yet one Xchange:
            I like the way she is handling now, lol!
            No more knocks or noises!
            1990 323s BG 1.6i
              awesome update! car probably loves you now haha
                Thanks!
                Yes, I hope for this, maybe these gifts she had to taste!
                at least to me - definitely, lol
                1990 323s BG 1.6i
                  awesome work.
                  ~~~~~~~~> Thanks again to member gooseinyou for the familia garnish <~~~~~~~~
                    Brake upgrade:
                    Brembo Rotors, Ferodo pads and lines...
                    In the beginning...
                    Mazda repair kit:
                    1990 323s BG 1.6i
                      Cleaning and lubrication
                      New seals are in the caliper:
                      Yes, the springs are installed incorrect
                      All stuff is together:
                      Old crappy things:
                      I haven't painted calipers in red so as not to seem ricer, lol
                      1990 323s BG 1.6i
                        Nice! I envy your bushing upgrades, all of my rubber end link and lca bushings are mostly shot like in your pictures.
                        1992 Mazda Protege DX Manual - 5/30/2006 R.I.P
                        1992 Mazda Protege LX former Manual - 2/2/2010 Parts Donor
                        1994 Mazda Protege LX Manual swap Daily Driver W.I.P.
                          awesome update man! Had much experience with things like that in the past?
                          I love working on brakes and suspension, it's by far my most favorite task on a car.
                          I remember pressing in all the poly bushings (first time) and that was something different haha.
                            Thanks!
                            No, that was my second attempt , lol
                            New toy:
                            1990 323s BG 1.6i
                              New clutch "kit" is ready:
                              1990 323s BG 1.6i
                                when's the clutch kit going in? planning on replacing the rear main while you're at it? Looking good tho man!
