323 BG sedan EDM worklog
    Thanks! Yes, I want replace rear main seal too - it would be strange to detach tranny and don't look at rear main!
    when's the clutch kit going in?
    It is almost replaced, too much photos must be processed, lol
    The main culprit is clutch disc
    1990 323s BG 1.6i
      Front and rear engine mount by Mazda, lol
      1990 323s BG 1.6i
        Preparing for tranny detach:
        Very useful stuff for assembling step, lol, through some days especially
        Front mount, holy oil leak...
        A little bit of russian text, lol (for local community)
        Inner CV joint
        Important support:
        1990 323s BG 1.6i
          Tranny has been detached:
          The grooves have almost disappeared from the surface of clutch disc
          Flywheel has been detached
          View on the rear main seal...
          1990 323s BG 1.6i
            New rear main seal try-on:
            Installed:
            Before:
            After (like brand new, lol):
            1990 323s BG 1.6i
              looks awesome! well done. Did you use any type of sealant around the main seal before re-installing the clutch system?
                Thanks for comments!
                If you're talking about sealant on the "cap" of rear main seal - I hope, here it is:
                1990 323s BG 1.6i
                  Looks good man. I just did mine on friday, Always fun lol. What gear oil are you using?
                    Thanks for opinion!
                    Not the best choice, but BP ENERGEAR SGX 75w90
                    How often do you change oil in gearbox? 50к-75к miles?
                    1990 323s BG 1.6i
                      yep, that's what I was talking about, usually I put some on the outside as well between the main seal housing and the oil pan seal.
                        +1, but I haven't intermediate photo of that process, my fault
                        What about this sealant - it has an inscription "Made in USA", is it true? haha
                        1990 323s BG 1.6i
                          made in the USA, printed in Ukrainian lol, why not
                            New bearing:
                            Hand made center tool, lol
                            Clutch kit has been assembled:
                            Applying a liitle bit of grease:
                            Exciting moment:
                            1990 323s BG 1.6i
                              Brand new mounting brackets, lol
                              Oil pan paint restoration:
                              "I see a red door and I want it painted black..." (c), lol
                              1990 323s BG 1.6i
                                Final assembling:
                                Job has been almost done...
                                Slave clutch cyl and
                                PS comparison of thickness
                                1990 323s BG 1.6i
