323 BG sedan EDM worklog
    this car will be almost brand new soon enough! job well done sir
      hi i was wandering what did you use to clean the trans oh and it looking very nice man keep up the good job.
        Thanks! I hope this process isn't just wasting time and money
        I've used liquid engine degreaser - it sucks, then I made "cleaning operations" the mechanical way with this:
        Quickly and easy!
        Thanks, I will try to continue
        1990 323s BG 1.6i
          Engine bay UPD
          Polishing of valve cover has amazing results, hehe
          Was
          Now
          I'm frightened open up the hood in the direct sunlight, it's blinding me, lol
          1990 323s BG 1.6i
            turned out nice!
              yeah relay nice i will try it.
                Thanks, hand polishing is very sweaty work
                My T-shirt probably contains a pint of fluid, lol
                The result could be even better with a polishing machine, but I haven't found these little polishing wheels...
                Try what?
                1990 323s BG 1.6i
                  Valve cover looking good!!
                  also you should get yourself that exhaust mainfold heat cover.
                    Car looks good? And you guys have stamped steel oil pans?
                      Wow!
                      This is good work.
                      1990 Protege 4WD
                      1 3 5
                      2 4 R
                        Thanks for comments!
                        It is extremely rare thing - they are in bad shape
                        I want try heat cover from Chevy Aveo , lol
                        Yes, B6 has steel oil pan, and BP, afaik, has duralumin one. Is it true?
                        Originally posted by me109 View Post
                        Wow!
                        This is good work.
                        Thanks! That's about valve cover? Now I have to make such shine for every bolt under the hood, lol
                        1990 323s BG 1.6i
                          Heater control lighting has been fixed:
                          1990 323s BG 1.6i
                            EDM clearcorners:
                            I have to install parking lights in them from stock EDM corners, and they will be ready for use!
                            1990 323s BG 1.6i
                              I say you pull the lense off and paint the chrome backing black lol, that's just me personally, would look more factory since our corners have barely any reflective chrome in them lol.
                                look nice
