Alright, before i close the door on today's parts orders....
Are there ANY aftermarket mounts i can use besides the AWR Probe Front, and AWR MX3 rear? Or am i just stuck using those two and then going homegrown for the side mounts?
I don't think the BP AWR side mounts will work with the V6 mounts, but if any were to work I'd imagine the passengers side mount, since it was just the bracket that's needed for the V6 swap.
As for the trans mount, afaik it's different, you'd have to compare your KL and BP trans bracket to check if they line up or not, I don't have access to the KL ones atm.
Bracket for side mount? Do explain? (I haven't looked much into mounting besides knowing that i needed MX3 mounts, which i have.)
Are you talking about the bracket that goes over the mount on the KL itself?
So... when mounting a KL, i can use the passenger BP mount, just swap to KL bracket? (Just to make sure i've got this right before i order something i don't need.)
[edit]
I don't see BP side mounts on AWR's site.
