I hope this helps and doesnt confuse you any more lol
Concealer404's KLZEscort thread
Originally posted by wgnths View PostSorry to tell you but i think the MX3 GS speed sensor is not the same as the Ford one. I know for sure the GT is electrical and the Mazda ones are mechanical, not sure about the MX3 GS tho. Some one correct me if im wrong.
You might be able to just put the entire speed cable along with sensor into the Mazda from the GT and be good. It connects the same behind the cluster.sigpic
92 240SX: KA/T25, nerd mobile
pull the gears out and check-Jack
Originally posted by concealer404 View PostDo we know what the electrical connector does? Is it a legacy connector for ABS maybe?
Are people using the EGT sensor in the MX3 trans with this swap? I'm using stock EGT cluster for now. I'd like it to work.sigpic
Originally posted by Mazda_Powered View Postpull the gears out and check
Originally posted by atomicEGT View PostIt's there on pre-ABS cars and 1.9s, so probably not- I'll check my FSM later.
The gear is the orange part of the speed sensor that Mazdapowered posted earlier. He was saying to pull that out and see...atleast that wat i understood.
Your right Atomic, EGT is a combo of both with the Mazda is straight up mechanical.
Im assuming if your using the EGT cluster in your MX then ya your EGT speed sensor with cable shall work. give it a go.Anyone knows what 9K rpm feels like? I do
93 Mercury Tracer SW
01 Honda S2000 Future Boost
Originally posted by white-lightning View PostCruise control is what the electrical signal is for.
Ah, that makes sense. Ok, well, i removed that, so i guess that makes things easier if i have to find a new one.
Originally posted by wgnths View PostThe gear is the orange part of the speed sensor that Mazdapowered posted earlier. He was saying to pull that out and see...atleast that wat i understood.
Ok, perfect. So the only question is whether or not the EGT sensor will work in the MX3 trans. :D
Oh, and Jack? Thanks for the PM!
is this thing done yet? im really contemplating gathering the parts to start this quickly. pretty sure my headgasket went on this junkyard engine and i can do the v6 swap cheaper than replacing the gasket and other parts1994 Escort LX Wagon
2013 Hyundai Veloster Turbo
91 EGT - Junked May 2012
Originally posted by MATT91GT View Postis this thing done yet? im really contemplating gathering the parts to start this quickly. pretty sure my headgasket went on this junkyard engine and i can do the v6 swap cheaper than replacing the gasket and other parts
Rest of the drivetrain, whole brake setup, and strut/coils are coming out tomorrow.
My transmission isn't done yet, either.
If it runs and drives at this point before the first snow, i'll be happy. Got sidetracked with the Meeotter.
Catching this thing up with a bump from the dead since i'm waiting on parts and such because this whole thing has been a gigantic cluster**** of things not fitting, Mazda not getting me the right arts, parts arriving broken, a car that fought me every step of the way in teardown, etc etc etc...
10/2/11
Do do doooooo...
Disgustingly dirty engine bay. Pretty sure the crank seal had gone out on this motor before i pulled it. It was leaking everything, everywhere. Can't believe it still ran. There was a half inch of oil gunk build up on the passenger side of the bay. :tard:
Test fit... suspension seems to be fitting well.
Cleaned and masked off. Notice the large patches of red paint just missing, exposing what looks to be bare metal underneath. This is where the biggest oil build-ups were. :lol:
Race car kit being delivered!
Hideous garage is hideous.
It's not a Lightning, but it carries parts overnighted from Japan just fine!
Unloaded, doing some cleaning.
The doriftu car gets moved out for more workspace.
She's up on stands finally to finish up the teardown.
Stock exhaust vs. Corksport exhaust. Not a bad way to save 30-40lbs!
Cleaned up MX3 crossmember a bit. Should have seen how disgusting it was.
In case anyone follows in my footsteps. :p
Rear control arm hardware
(2x) 28-112 $34.18
(2x) 39-037 $12.02
(2x) 34-662 $7.82
(2x) 28-113 $31.18
(2x) 34-662 $7.82
(2x) 39-037 $12.02
Rear Trailing Link Hardware
(2x) 28-116 $13.16
(2x) 34-662 $7.82
(2x) 28-114A $18.16
Rear Strut knuckle nut/bolts
(4x) 28-115A $???
(4x) 28-091 $25.24
Front Control Arm Hardware
(2x) 34-113 $17.98
(2x) 34-409 $7.74
(2x) 99971-1200 $3.00
(2x) 99971-1400 $2.40
(2x) 99921-1400 $6.90
(6x) 34-128 $39.48
(2x) 34-403 $???
Front Strut Knuckle nut/bolts
(4x) 34-112A $26.32
(4x) 34-091 $13.60
MX3 north/south Crossmember hardware and bushings
(2x) 39-811 $10.16
(2x) 34-403A $8.18
(2x) 39-813 $9.86
(2x) 39-830 $10.16
(2x) 39-820A $10.16
(2x) 99940-1211 $5.56
UGH. This ended up being a bit over $450 at the local dealership. I did it, but wouldn't suggest anyone else do it. Not worth it.
