My old wagon got aerosol bed liner, it worked pretty damn well, but I'm actually thinking of making some molds and laying up some carbon fiber pieces. It would be beneficial, as they would work on the white five too, plus anyone's sedan, wagon, or 5door who wanted a set. I'm sure if I could do them for under $150 I'd be able to sell a few sets.
Cody's Silver 95 Escort Wagon
omfg I need an RMM grille again... =/
I totally thought about making some window trims before.. but at least for me, I felt it was easier just to paint/dip them.. CF vinyl if anything too...
Now, making a mold of the RMM grille... yes, do that.1992 Ultra Blue Metallic EGT - The 'scort with no name - crap>reliable daily>rallycross prep>stage rally
the grille came out GREAT. is that the civic hatch spoiler??
The last pic, i love it. simple and clean.
Nice mudflaps1992 Ultra Blue Metallic EGT - The 'scort with no name - crap>reliable daily>rallycross prep>stage rally
damn! already turning out nice!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by worldhazard View Postthe grille came out GREAT. is that the civic hatch spoiler??
Nice mudflaps
It is that modified civic spoiler from my old wagon. I'm gonna paint it the same way as the grille, but I'll have to hit it with some sort of plastic primer first. I guess I'll need some white base after prime, that's what the grille was, and the color match is almost dead nutz.
Thanks
Originally posted by FE3-323 View Postdamn! already turning out nice!Current:
68 Torino GT Fastback
86 MR2
91 F150
94 Escort Wagon BP swap
99 Escort Wagon BP swap
00 Miata LS
08 Arrow AX8
14 Mazda5
I'll have more stuff to update tomorrow, after I install some parts. I did just purchase a turbocharger and manifold for this thing though, thanks Matt. I've got pretty much everything else to make it work just sitting around. It'll also get the 2.5" Mandrel bent exhaust from the 5 door since that thing is getting a 3" job...Current:
86 MR2
91 F150
00 Miata LS
08 Arrow AX8
14 Mazda5
I might snake those studs in a few weeks for a future spi head swap for more boost. I'm just gonna do 30lb injectors, RR-AFPR, AFMU, fmic, vented bpv, blowthru maf, E85, with a Wideband sensor and 5psi to start. I'll turn it up once I get it dialed. Then I'll get a t-bird hybrid built for when the time comes to spi hybrid the engine, and push more like 17psi.Current:
86 MR2
91 F150
00 Miata LS
08 Arrow AX8
14 Mazda5
so minty clean. im jealous---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I've been busy hoarding away some parts for this pig. Weather sucks today, so I'm not in the mood to really do much, but here's an update:
VJ14
EXP/TurboGT manifold
36LB injectors
Cartech AFMU
AEM Wideband
Autometer Boost Gauge
Innovate Turbo timer
SVO oil feed fitting
1 (of 2) 300zxTT BPV
Whitey Bend Downpipe
full 2.5" Stainless Mandrel bent Exhaust, w/ Cat, 2 resonators, and a ZX2 S/R borla muffler and sleeper 2.5" tip (not pictured) it'll be slow and quiet.
Saab dual pass FMIC
a 5lb spool of aluminum mig wire (for oil return, charge piping and mounting the BPV)
2" Aluminum charge piping with 3 ply silicone couplers and t-bolt clamps (will be 1 piece turbo to IC, & 1piece IC to TB)
AEM water-meth Kit (not pictured)
RoodWorks passenger mount, window weld filled f&r mounts
K-sport coilovers, getting a set of QA1 springs- 7" 250LB/in front and 10" 200LB/in rear (springs not pictured)
Rear Disk swap (not pictured)
That'll be about it for performance, I have some other goodies for the interior and exterior...
Still need a clutch, and to relocate clutch slave and PCV tube, as well as an AFPR to drop base fuel pressure. It should only take a good weekend to get this thing done. I only plan to run wastegate pressure on this block, maybe I'll slap together a 1.9/SPI-hybrid for 15psi later. (god knows I have a few 1.9's laying around)Current:
86 MR2
91 F150
00 Miata LS
08 Arrow AX8
14 Mazda5
