haven't been there in awhile. props on the motivation to get it all done
Rc's 90' 4WD Protege
Got the dash and everything swapped in. Even swapped in the adjustable LX Steering column.
So I got the following switched over, and only took two weeks! Lol.
Rear seat to an LX seat, Carpet to Dark Grey, Fire Wall harness, Black Dash, and LX Steering Column.
Power Windows/Locks/Mirrors to come!
Also, got me a Rear Fog Light Garnish!
Proud owner of way to many!: (Click one to view)
1994 Ford Escort LX White (The Original)
1991 Ford Escort GT Red (The Main/DD)
1993 Ford Escort GT White (SOLD!)
1990 Mazda Protege 4WD White (New Toy!)
1991 Mazda Protege 4WD Blue (Turbo Parts car for the White one)
1994 Mazda Protege DX White (Parts car for the White 4WD)
You got better door panels and seats, so you win.Proud owner of way to many!: (Click one to view)
Well yeah mine runs, on a SOHC. Lol. With no lsds!!! lol. but yeah got that interior almost finished...need to get the power window motors and harness installed with door panels and then I need to find some good seats! Then interior is done.Proud owner of way to many!: (Click one to view)
I'll take pictures of the seat brackets i made. ( I'll warn you now they are archaic since no one ever sits back there anyways. Lol.)
And my carpet was out of a 4wd i believe. It was from a parts 4wd car i bought. it appears to be 4wd. it fits perfect and ive been told fwd doesn't fit for crap!Proud owner of way to many!: (Click one to view)
Okay, I grabbed some pics of the "Brackets" that i made for the seat back. To use the LX rear seat in the 4wd I needed to move the seat back latch up about 3/4". So I made a bracket that bolts to the original latch spot and then drilled holes in the bracket at the appropriate height. I drilled holes through the frame above the old holes. I then got long bolts and ran the bolts through the latch, bracket, and the frame.
So it goes Bolt -> Latch -> Bracket -> Nut -> Frame -> Nut.
You can kind of see it in the pictures.
Also, the Seat bottom needed to be shaved down a little bit on each side and a bunch in the center. Also there are two bars that are part of the frame that need to be bent up so that it sits correctly. I just flattened them up. The RED circles are said Bars and the GREEN circles are the center part of the seat that needs to be changed.
