If you can, get a picture. I might have missed it, but I thought it was a fairly large piece, no?
gtx wiring !? !?!?!
Here's a pic of the knock controller assembly.
Knock Control Part #
BP26
E2T06177
9802G
Resistor Part #
056783-0031-------------------------
'91 LX
'03 Mazdaspeed Protege #235
Dood u should take pictures of all the connectors that have to be spliced and maybe photochop them with arrows on how to splice them properly, make that part of the how-to.93' Noble Green MX-ZE (sold )
Here you go:
This one's from my GTR harness and thus the little difference in the part#-------------------------
'91 LX
yeah the only thing on that knock module assembly you need is the knock module, you can disconnect the resistor and relay.1994 Mazda Protege GTX
1990 Mazda Familia GTX BPT engine swap
Walbro 255lph fuel pump
ACT high performance street cluctch kit
Arospeed coilovers
Custom clear corners
Custom side markers
Custom MazdaSpeed windshield logo
TurboXS boost controller
1990 Mazda Familia GTX Front bumper
NGK 1 step colder spark plugs
Accel performance wires
Future Plans:
Rims, sideskirts, front mount intercooler conversion, GTR turbo, turbo timer, and paint.
Originally posted by emp94mazdayeah the only thing on that knock module assembly you need is the knock module, you can disconnect the resistor and relay.-------------------------
'91 LX
This works for me...
Originally posted by Gro HarlemCould someone PLEASE post a how-to on how to wire the GTX engine with the GTX harness?
It seems that 20-30 people have completed this swap, while either 1: not sharing any info about how to wire it, or 2: giving extremely vauge info about how to do it, that often conflict with what others say.
Can anyone PLEASE MAKE A HOW-TO FOR THE WIRING OF THE GTX MOTOR??? Would really help a lot of ppl I know who are trying to install their motors.
90 Protege GT(x)
the gtx harnes is not realy hard to instal it.
no need to extend the harnes. u can route the harnes going from under throtle body over the heater core hoses and inside the car. then i can move the ruber boot couple inches toward the ecu and tape it.
the conectors that conect to body hanes i used from lx.what i did on lx harnes i puled all the conectors that go from body plugs to ecu.ecu plug opens and you can insert paper clip and relase the pins. then do same on gtx harnes .i would recomed doing this color by color. gtx uses more wires that go in those body plugs. not all off them are needed.
the fuel pump circut has to modified.its easy it has tobe wired same as lx so i think ther is only 3 wires to switch.
the second relay that is bolted to firewall next to knock module can be by passed(its there to control main pump and transfer pump) by wiring the realay nex to ecu as lx that relay becomes a fuel pump relay.
as knock control module i know that 88and up mazda 626gt,mx-6 gt and ford probe turbo use same stle knock control module.part number is difrent.
in mine opinin that will work but never tried one just an idea.i know plug is same and does same (transfers magnetic vave into pulses that are sent to ecu)
i just wrote what i had runing on mine car for over 2 years and never had problems .http://hometown.aol.com/d2maz/index.html
91 PROTEGE 4WD BPT RUNNING WOW TRACTION WITH 1.5 BAR(sold)
97 ECLIPSE GST SPYDER (K&N ,BCS MOD, GREDDY FMIC) new toy(sold)
99 PASSAT GLX V6 (OEM E spec navi, wife's car)
2006 JETTA TDI DSG 50 mpg(sold)
2006 EVO GSR
FIXING VW's for past 10 years
Well, I already extended my harness, so, oh well. I *tried* to get the wires out of the plug by pushing them, and I couldn't get them. If I could have gotten that to work it would have been so much of a cleaner wiring job. I saw an MX-6 turbo this weekend at protegefest, and the knock controller does look very similar.2006 Mazda 3 hatchback manual
