awesome, gas tank is leaking, what can i replace it with?
    just found out the gas tank on my 93 323 has ruptured and is leaking fuel, not good. I've been searching and sounds like the escort GT tank will not fit, but a protege one will, is this correct? also the pro LX has a bigger tank that may or may not fit? anybody have experience here? search wasn't very conclusive.
    93 323, 94 MX-3, 04 MSM, 83 Jeep Cherokee, 87 b2000
    www.gunshowracing.com
    just go get your tank resealed by a gas tank shop. very durable and done very cheap
      mx-3 is the same tank too fyi
        Just drop the tank and see exactly where or how bad its leaking. could just be the filler neck
        -Steve
        94' Protege < Worklog<SOLD!
        VF10 powered!
        262 Whp & 257 Wtq
        13.1@107
        '02 Suzuki Bandit 600s
          I put the car up on a lift, the rear seam is rusted through.
            Did you ever found out if the Pro LX tank would work in a 323?
