just found out the gas tank on my 93 323 has ruptured and is leaking fuel, not good. I've been searching and sounds like the escort GT tank will not fit, but a protege one will, is this correct? also the pro LX has a bigger tank that may or may not fit? anybody have experience here? search wasn't very conclusive.
awesome, gas tank is leaking, what can i replace it with?
93 323, 94 MX-3, 04 MSM, 83 Jeep Cherokee, 87 b2000
www.gunshowracing.comTags: None
just go get your tank resealed by a gas tank shop. very durable and done very cheap91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
mx-3 is the same tank too fyi-Jack
I put the car up on a lift, the rear seam is rusted through.93 323, 94 MX-3, 04 MSM, 83 Jeep Cherokee, 87 b2000
Originally posted by dustinlib View Postjust found out the gas tank on my 93 323 has ruptured and is leaking fuel, not good. I've been searching and sounds like the escort GT tank will not fit, but a protege one will, is this correct? also the pro LX has a bigger tank that may or may not fit? anybody have experience here? search wasn't very conclusive.
