The front swaybar on the Protege runs over the crossmember, there's NO way to get it out without dropping the crossmember unless you plan on hacking it up with a sawzall
Removal of the front sway bar.
Replacing the sway bar frame mount bushings alone could be a pita. There's very little room to work in there...-------------------------
'91 LX
'03 Mazdaspeed Protege #235
Originally posted by Identity_XReplacing the sway bar frame mount bushings alone could be a pita. There's very little room to work in there...
They're not half as hard as replacing the front swaybar IMO, they're a PITA to reach but if you lube them up enough they're not that bad._________________________________
'12 Focus SE hatch
'05 Saab 9-3 turbo (sold)
'90 Mazda 323 GT (sold)
'04 Mazda Tribute (sold)
'92 Mazda Protege LX (sold)
'91 Honda Prelude (totalled)
'91 Honda CRX SI (sold)
yes but in the mx6 it also runs over the cross member toosigpic gtx swap,pacesetter cat back exhaust,civic short shifter,both front and rear upper strut tower bars,high flow cat,,mx-3 lower tie bar,mx-3 front seats,zxtuner poly motor mount inserts,manual seat belt conversion,mx-3 lether shift boot,
come to mazdasnw.com if you live in the northwest
i actually just did my frost swaybar today. here is some detail
went to junk yard to get new swaybar ( mine was broke dont know why )
to get it out was failrly simple at the junk yard you can just drop the struts, dissconect the 4 bolts under the car that holds the arm thingys on stick a bar inbetween the arm, and the frame and push down it will give you enuff room to wiggle the bar out.. putting it in is a lil more dificult ... i had 2 others to help and the sun was just about down.
we took out the 4 bolts on the arm, ( but i think we only needed to remove 1 the long one ) but we took out all 4 to be safe then we pushed down on both arms, and just wiggled it in. we had to jack the car up fairly high to get enuff play on the side we was entering from, because we could not get the far side of the bar up high enuff it was hitting the ground. but after 3hours of FN around with it, it was in and i started to place back on all the bolts. i took my camra for pics but i left the lense open and batterys was dead and with the dieing sunlight the batterys was not on the top of the to do list.
it was and is a pain but can be done fairly easy with 3 people. it was our first time doing a sway bar . i hope this one dosent break but i did go to autozone and ger the polly bushings. rides much better. sway bar was broke when i got the car and didnt see it till we added the arospeed coilovers.
vps for the frame bushing that hold the bar onto the arm things.... turn the wheels it will give you enuff room to use a rachet or ( air rachet )Last edited by tempunlimited; 11-06-2004, 01:34 AM."im not a mechanak, but i can "WING IT"
"no i cant spell"
ill add some pics soon
you do realize that you spent alot more time F'ing around and wiggling the bar into place than it would have been to remove the whole front assembly and nicely put the new bar in place?
have a jack and 2 guys... save on the third lift it into place and attach it to the struts... work from there.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I swapped mine this weekend, i have a Whiteline front bar now. I already have the engine and box out the car, so it was nice and easy just to drop the subframe / lower wishbones off, swap the bar and fit it back on the car...
Does anybody have a pic of a 2wd front swaybar preferably off the car or a good clear pic on the car? I want to know if the GTR front sway bar will fit a 2wd car, as I have 2 of them sitting in the garage now. GTR front bar is 23mm, rear is 19.1mm hollow.www.323gtx.co.uk
www.323gtr.net
ZX2 front bar....24.5mm
ZX2 rear bar~13mm solid a major downgrade
GTR front 23 mm
GTR rear 19.1 hollow
early model protege LX
22mm front
20mm rear
later model protege LX
?? front
??rear---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
LOL he does know best
the rear swaybar on the GTR is a 19.1mm hollow bar... i just purchased one from cablemirc...
its the front GTR swaybar that is 23mm
heres a link with more info on that
you should explain the difference between what a hollow bar does in comparison to a solid bar..... just so everyone else is aware.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
