ok so only my right rear caliper gets stuck only when its gets really cold out, none of the other calipers get stuck ever.i have to jack the car up and tap the caliper with a hammer to get it to release i am wondering what could be causing this because it drives me crazy. and it only happens one in a while in winter please help thanks
brake help?
brake help?
sigpic gtx swap,pacesetter cat back exhaust,civic short shifter,both front and rear upper strut tower bars,high flow cat,,mx-3 lower tie bar,mx-3 front seats,zxtuner poly motor mount inserts,manual seat belt conversion,mx-3 lether shift boot,
come to mazdasnw.com if you live in the northwestTags: None
temp fix spray the spring and ebrake lever (on the wheel) down with wd-40 then when you have time go and regrease everythingCheck out the Pics
http://www.wihandyman.com/forum/vbpi...?do=view&g=228
Mazda's Rule Honda's Drool
ya i will grease every thing up and no my lines are not broken thanks for the helpsigpic gtx swap,pacesetter cat back exhaust,civic short shifter,both front and rear upper strut tower bars,high flow cat,,mx-3 lower tie bar,mx-3 front seats,zxtuner poly motor mount inserts,manual seat belt conversion,mx-3 lether shift boot,
Does this happen with E brake when engaged?
How long has it been sense you flushed brake fluid? Might be water in fluid.Mx3 RS,BP-turbo
http://www.cardomain.com/ride/2628805
