Better injectors
    were you able to adjust it at the dyno? how do you adjust it. i suppose they had a wideband at the dyno to adjust it for you.
    98 Protege SE
    1.5L Turbo
      there was nothing to adjust, my injectors were not big enough, i just had to turn my boost down to 5psi, but once i get bigger injectors their is no way to adjust the amount of fuel, unless i get some sort of fuel managment, like an apexi air fuel controller.
      .....HELLO MY NAME IS BEN...
      186.08whp
      225.94wtq
      torque monster!!!!
      dyno graph 8-10-and 12psi
      blahblahblahblahblahblah
        guess i should just get the air/fuel checked first before i go buying bigger injectors...
        98 Protege SE
        1.5L Turbo
          Here is where the gas is leaking.. i'm going to get the new o-rings ordered today.. unless napa has them in stock.. which would be a bonus. do you think its hard to install on your own? can i clean the injectors while i'm at it?
          98 Protege SE
          1.5L Turbo
            yeah your def leaking fuel, its not hard at all, as for the cleaning, im not too sure what you can do for that, i know you can send them out, and have them cleaned, but then you would be without injectors, so thats dumb.
            186.08whp
            225.94wtq
            torque monster!!!!
              the car is my secondary car so losing the injectors for a bit doesn't bother me.. i'll be doing alot of cleaning over the winter if i can find a garage to store my car in...
              98 Protege SE
              1.5L Turbo
                yeah dont know if i would bother with having them cleaned right away, just out them back in, get it on the dyno, and see where you are at for air/fuel. if your all set, and have great air/fuel, then dont worry bout bigger injectors. but if you get it on the dyno, and you find your air fuel is way off, and need more fuel, then do some testing, first test your fuel pressure make sure you have plenty, then add bigger injectors as needed.
                186.08whp
                225.94wtq
                torque monster!!!!
