AH HA! That crazy braking/idle problem actually has a solution.
"Breakout Box" for 97-98 TPS??
Originally posted by bp 1.8ocd, it doesnt make sence for there to be an adjustment tool for youre tps, if there is no way to adjust it right? theres got to be somthing missing here.sigpic
Thanks Bruce for the pics, my tps is diffrent then that...but mine is also wired diffrent...Yours goes LG/R, L/Y,B/R. from top to bottom...mine goes L/Y, B/R, LG/R. Maybe thats it.. maybe its wired wrong but its wired exactly how it is on my diagram so i dont know...I need a pic of a 97-98 TPS. then i could see if my wires are diffrent. Anyone got one?sigpic
OCD, if that's how your wires came on the engine then chances are that's how they should be. All I did was splice the 1.8 tps plug wires (color match) to the 1.5 harness. You really shouldn't have any problems with your idle. I would say check your throttle cable. Then check your idle screw. (But don't move that screw to much. You don't want to go through what I went through. I had the car stalling on me at lights when I would neutral up. changed the idle screw and the adjusted the throttle cable and it went away.
what you do first is set youre idle speed by disconnecting the isc and screwing in the air bypass screw on the top of the throttle body all the way closed. then adjust the butterfly via the set screw obtain the idle speed you wish. the air bypass screw should normally only be used for minor adjustment. this is important because the tps uses the idle speed as a baseline for its setting.
Bruce
Ive stumbled across something else that might be causing my problem....Maybe its not the tps..I have a 96 kia motor, and 98 mazda. Thing is, if you look at 96-97 kia bps. they have 2 throttle cables... one on the bottom of the circle thing on the throttle body and one on the top. Yet the mazda bps of that year have only one throttle cable. I wonder could this be causing the problem...Maybe my ecu is wanting to run it the one throttle cable way, but the engine wants to run with two.. ill but up some pics so you can see what i mean. Top is mazda with one cable, bottom is kia with two. What is that top cable for anyway??!sigpic
