my 2 inch drop for my 2gen i think is enough cos when ever i parked next to my mazdaspeed you can clearly see the difference from roof line to bumper. Makes the car looks wider too. I havent scrape to anything yet but I guess I just have to really be careful.
just dropped
Originally posted by rustyNice info fireguy, Once I get around to it I think I will just go some chassis tech full coilovers and pick my spring rate for the setup. They custom make each pair for $379. These are 3" adjustable as well.
I have recently put 17"s on my z5 and would like to drop it 2" seems more than enough to eliminate all the space between the wheel well and the tire but it seems that everyone is saying that 2" drop isn't enough, does everyone else here have smaller rims, feedback is greatly appreciated. I have found some afordable springs and wondering if the oem strut towers can accomadate a 2" drop with little compromise in comfort? please check the link and let me know, thanks
Free Imagessigpic
Originally posted by firelizardGood call, just remember to get appropriate dampers. KYB GR-2 is not strong enough for stiff springs or big drops. Look into at least the KYB AGX.Almost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms sideskirts... check
ms rear skirts... check
ms spoiler... check
ms struts... check
Still trying for a bp swap..:
Wondering if either firelizard and or strutman have 17's? and whats mr. gasket crap? http://cgi.ebay.com/ebaymotors/SPRIN...spagenameZWDVW Also curious if anyone has attempted the st route to drop their 95-98.
Free Imagessigpic
I think a 1.75-2" drop will be enough and should look just right with 17" wheels.
The Springtech springs in the link are only a 1.75" drop and I think that is a good match to the GR-2s (unless the spring rate is overly stiff). If you asked me I would venture to say that 2" is pretty much as far as you want to have the GR-2s compressed for daily driving. Keep in mind they are not any shorter than the stock struts.
Any smaller wheels like 15-16" will require at least 2.5-3" of lowering to get the ideal look. Ride quality will seriously suffer as the stroke of the suspension will be extremely compromised at that height though.
I suspect that more than 2.5" will not be practical on any of the dampers available on the market (I don't know how short the Koni inserts or the GAB shocks are but they are both rather expensive). The only way I can forsee acheiving the right look and functionality on wheels smaller than 17" is to upgrade to some kind of shortened struts or coilovers.
I have my 15" Miata wheels on the stock ride height (with over 300 000 Kms) right now and I can easily fit my entire closed fist between the tire and fender. I took a quick measurement of ~4.5" of gap in the front and probably more in the rear. It's completely rediculous!
The Mr. Gasket things are spring clamps. Stay away from them if you know what is good for your car.
My Z5 is slow enough already. I'm weary of any wheels bigger/heavier than a lightweight 16".1998 Mazda BHALP SE - Rain Forest Green Mica
Pacesetter short shifter ; Depo tails (thanks beetle_orange) ; Custom CAI nearing completion ; CF hood on the way ; Brembo blanks & KVR pads to be inst. (thanks Pigeon) ; Goodridge brake lines to be inst. ;
Much more to come...
