LOL,I had the intention of doing more updates but i havent done anything with the car for some time.
Got these today.
werd---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Please keep knickerz on ! LOL
Originally posted by bpt323 View Postwerd
Ok kids i admit i have been lacking in this thread.
I did manage to get it to the shop recently for alignment.
The car drives really tight.Bumps are firm but controlled.
No see-saw effect at all.
I still need to install the rear stab bar and the front links are shot.
Having the camber plates for the alignment was a luxury.
Toe was way out (ofcourse)
I will play around with the damper adjustment and see how it impacts the ride/performance.
Sorry for not updating but ive been busy with the ITB,s and tranny as of late.
This is what I am getting my brain around right now too. I have all the new struts , brakes and ground control coilovers in ... but am now wondering how to adjust my rear ends camber / caster with the stock suspension.
Have you ever used the camber bolts that are on the market. They replace the stock bolts which bolt the strut to the spindles .
Originally posted by 323Permin View PostThis is what I am getting my brain around right now too. I have all the new struts , brakes and ground control coilovers in ... but am now wondering how to adjust my rear ends camber / caster with the stock suspension.
You wont have to worry about caster in the rear.Powered by ACME
how come your camber°'s aren't equal?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323 View Posthow come your camber°'s aren't equal?
The whole alignment could be tweaked,I did it on a saturday when i was off and the tech who was working at the time needed the rack to do an aligmnent so i was rushed and just went for "green".My tires are junk from the previous owner dropping the car and driving .When i get new tires i will redo it with much more fuss.
At least i can drive on it now.Powered by ACME
i understand that, adding plates up top usually has a crazy effect on the alignment.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
you don't really want equal camber on both sides anyways, since roads are crowned you would be pulling to the right if it was equal...you want more - camber on the left side so it will over come the crown and stay fairly straight.
suspension is looking great man!-Jack
Originally posted by Mazda_Powered View Postyou don't really want equal camber on both sides anyways, since roads are crowned you would be pulling to the right if it was equal...you want more - camber on the left side so it will over come the crown and stay fairly straight.
LOL ya i ,i have the left front camber plate hard over to the left.Another degree of adjustment would have been nice.
In a pinch i will sometimes drop the right side in a bit if there is no more room left on the left side but i was outta time and had to get off the rack.Powered by ACME
Originally posted by nerd racing View Postwhere did you get the koni inserts and what did they run you? also what spring rates are you running? I have 450's in the front and 350's in the rear and its a little crazy on my car... lol
There is another company i was going to use called Truechoice.
Price-wise ~ $ 185 each.
Im using a ground control kit for 99-00 protege i cant remember off the top of my head 350/250 but ill check and let you know.
Thats alot of spring you have if you are running stock struts.
The inserts i used come standard or race valved,i used race.
They also come single and double adjustable,i coudnt afford the DA's lol.
They work really well ,no teeter effect at all and they soak it all up.Powered by ACME
Originally posted by steeb View Postsorry but whats "scrubbing"? and how do u know when ure car is "scrubbing"?
i have 550/350# springs on my mx3. i actually like it better with 350/550,Powered by ACME
