yeah... walmart should have the innertube you need. they're fairly inexpensive.
Big Hesitation Problems
My friend has a 2001 Celica and he frequents the NewCelica.org boards. Apparantly, they have the same issues as us as far as hesitation and lack of power at low RPM's. In fact, the Celicas appear to use the exact same MAF as our 1.6 ZM-DE engines.
"Blue Bomber" on NewCelica.org posted an informative thread that may of some use to the do-it-yourselfers around here. He shows several methods of modifying the MAF to read the air correctly. Here is the thread:
how do you know its the intake at this point? sounds like you've got something else wrong. check your wires and plugs. possibly a bad coil pack. because this shouldnt be causing that bad of problems.. might also just be a bad MAF in general. take the intake off, put stock back on, and take it to the dealership to have it checked. it was under extended warranty for like 75000 miles i believe.-mike lucero
1988 Mazda 323 GTX
2001 Isuzu Rodeo
even if you put the stock intake back on, and it stops doing it.. it doesnt mean the MAF isn't bad. i've had that happen before. good luck with that. once they fix the maf.. do the seal. and if it doesnt help... you're leaking somewhere else. hopefully the dealership fixes whatever is wrong.-mike lucero
1988 Mazda 323 GTX
2001 Isuzu Rodeo
