Originally posted by bruce95fmla
What can I do to upgrade my brakes?
yeh have to agree with jessesays the brakes dont seem to have any probs on my car either!?!? are u having problems with ur brakes or just want some extra braking power?? are they fading because slotted rotors may reduce fading by reducing the heat of the pads but i would reccomend getting a decent set of pads before anything else, especially before fitting rear discs as the costs are high and the results are not so high. Under hard braking most of the cars weight is trandsfered to the front and the front brakes do most for the stopping, my protege also seems to not mind lifting its inner rear wheel in hard cornering and braking!Pioneer 7650 HU
2x Pioneer 10" subs
Pioneer 2 way 5x7's
Pioneer 3 way 6"
Pioneer 4 x 100 WRMS amp
Pioneer 2 x 100 WRMS amp
Originally posted by charlesOK, but do they all share the same proportioning valve?
so I guess you are right, the brake distribution bias is different between the 2.
I still think replacing her LX front brakes with ES brakes would improve her braking.
However, I think, given the options available in terms of what to upgrade first, all Jo may really need are probably just better tires (Toyo Proxes T1-S comes to mind) and better brake pads (Hawk HPS) to make her car brake noticeably better.
oh yeah, bleed the brake lines while you're at it!
'04 Titanium RX-8
then again, I suspect Jo's car's brakes will never endure track-condition stress, which most of the mods we're talking about will show up most in terms of braking improvement. On the street I'd figure the stock LX setup should be fine for doing what it's suppose to do. thus it begs the question, would any of these mods have prevented Jo from rearending someone??? Is it worth it for Jo to upgrade it if she's never gonna see any track time in this car?
'04 Titanium RX-8
yea, track quality brakes are completely useless on the street. like the other day, i was passing this guy from the right side and he started turning into a gas station infront of me from the left lane, and didnt see me, so i slammed on the brakes but unfortunately they didnt break well enough, and i jumped the curb and scratched my shiny rims.... yep, total waste of money to upgrade brakes!2002 Protege LX
] Eibach Pro Springs [] Tokico HP shocks [] AWR rear swaybar [] PIAA Super Plasma GT-X [] custom CAI [] 30% all-around tints [] 17" Flik Wasps / Kumho Ecsta 711 tires [] APC Eurotails [
Originally posted by ZoomZoomHthen again, I suspect Jo's car's brakes will never endure track-condition stress, which most of the mods we're talking about will show up most in terms of braking improvement. On the street I'd figure the stock LX setup should be fine for doing what it's suppose to do. thus it begs the question, would any of these mods have prevented Jo from rearending someone??? Is it worth it for Jo to upgrade it if she's never gonna see any track time in this car?
There is a chance that she may have been able to stop sooner or slow down and evade the sudden stoped car in front of her, if she had better brakes.
I really don't care what anyone says. Good brakes are what works the most at stoping the car in the time of need, assuming that the driver presses the pedal.
I converted my rear drums to discs on my protege and noticed a increased amount of braking from the rear. People tend to think they don't make a difference but they do.
I have the stock size rotors and calipers on the front of the DX protege.
However I replaced the stock front rotors with EBC cross drilled and slotted rotors 3 years ago. They have never warped and work excellent with basic pads. ( I haven't run hawks or anything yet... only kvr carbon's (semi ok)).
I can't count how many times I have had to do the last minute holy crap stomp the pedal, sudden stop thing. I am definetly sure that if Motegi upgrades her braking system she will experience much better braking. (assuming her shocks are good also).
Originally posted by bruce95fmlaGood brakes are what works the most at stoping the car in the time of need, assuming that the driver presses the pedal.
My brakes are weak, and it's happened quite a few times before - me making emergency stops, and stopping just a couple of inches away from someone's bumper. If I stop faster, then chances are the person behind me might not stop as fast and BAM...
Originally posted by IntruderThen YOU get rear-ended, not the person in front of you...
Q-So would I rather someone hit me in the back than I hit someone in the back.
A- Yes.
Tires are more important."Never run out of real estate, traction & ideas at the same time"
-93 MR2, 129 ES
ClubProtege.com Tech Articles
ummm, then press the pedal with less force... YOU are still in control of how much you press them."Never run out of real estate, traction & ideas at the same time"
-93 MR2, 129 ES
Originally posted by Unleashedyea, track quality brakes are completely useless on the street. like the other day, i was passing this guy from the right side and he started turning into a gas station infront of me from the left lane, and didnt see me, so i slammed on the brakes but unfortunately they didnt break well enough, and i jumped the curb and scratched my shiny rims.... yep, total waste of money to upgrade brakes!
did you lock the tires?"Never run out of real estate, traction & ideas at the same time"
-93 MR2, 129 ES
Driving around in a WRX it stops worse than my Protege. wHAT!?!? Is those tiny rotors!?!??! I guess not. It's the tires and the pads. The pads on the WRX have been heated to hell and are no longer effective. Also, the system needs to be bled. But the big brakes look neat under those 16" wheels.2006 Mazda 3 hatchback manual
