I did compare, the BG 323 is approximately .2 inches wider. i actually have tracer/323 shafts in my car from an F-series transmission right now.
GTX Axle questions
That would be sweet, some guy over at FF.com made one with a Pulsar GTI drive train. There is more fab work with a festiva because of the smaller engine bay and almost no current hump to accomodate a drive shaft. Look up EVOGUN on fordfestiva.com, it can be done.2011 BMW 128i 6 Speed Manual -- dd
1990 Protege 4WD 5 Speed
Does anyone know if it would be possible to use a brake booster and clutch system from a RHD GTX in a LHD car? I need to swap my brake booster if I am going to go with 4 wheel disk brakes, I know that much anyway. I also have a question about the AWD spindles, could you use stock BG struts with AWD Spindles and Hubs? I want to get everything setup and ready to go, I am going to do this over the spring and summer because I can't wait till next year to do it.2011 BMW 128i 6 Speed Manual -- dd
fwd struts do work, the rears are just stiffer for the extra weight. so if you use stockers your rear will sag. nothing a coilover setup won't fix though.
I think you can use the RHD booster, afaik its the same as the LHD.No car! I soldz it. Now I have a truck. I like it, but apparently it has a hard time keeping up with a slightly modified 4WD protege with half the hp. Neat.
I do not have any suspension right now, I have been working through that in my mind, I may be able to get away with some slick moves and use the aspire suspension with the miata rear, I would be getting much stiffer springs and some Gr2's. The front is still getting worked out as well. Lets just say it will be more clear once I can source spindles, hubs, axles, and the rear suspension. I am not going to get into cutting my car until it gets A LOT warmer...2011 BMW 128i 6 Speed Manual -- dd
Originally posted by nerd racing View PostYes I am, I am in the planning stages of what will hopefully be my senior capstone design project for my BS in Mechanical Engineering Technology. I am starting out with a 1995 Ford Aspire, which is hardly stock when it comes to the drive train. I've already swapped in an F-series Transmission out of an 88 Mercury Tracer (only had 18K miles and I got it for $50), And it is currently powered by a B8-ME out of a 92 Protege. I have roughly $700 into the car, including what I paid for it. Its like driving a fairly powerful go-kart on the road everyday. I want to do something that will stand out for my senior project and what better than an AWD Aspire? Plus how much of a sleeper would it be to all those unsuspecting honduh drivers that think their cars are hot as hell. :D
And the US axles should be the same as the gtx/gtr gear box. Ive had a US trans, gtr-ae trans, and gtx trans in this car at one point using the same axles. Im using gtx axles in the front and stock US in the rear. Also still using the stock US drive shaft.
Good luck with your build! I think a fully stock looking 4wd protege would be a better sleeper cause its a sedan.
Originally posted by TurboProto View PostWell your gonna need to have some turbo power to get away from any honda in a 4wd car.
Anyone know what gear ratio the GTX rear end comes with?2011 BMW 128i 6 Speed Manual -- dd
Originally posted by nerd racing View PostI totally agree with you about the boost and with the sedan, but in theory the aspire should be faster because its lighter. If you think about it, no one gives the aspire any respect, not even the festiva guys. Plus I just want to be different, and an awd aspire is as unique as they come.
90-93 miata rear diff is the same, 6". the 1.8 used a 7", same as the rx7.
as for the rear lsd in the GTX, I've seen it quoted that it does. BUT they didn't specify BF or BG. So I think the BF had an LSD while the BG was open. I could be wrong, I'm open to facts.No car! I soldz it. Now I have a truck. I like it, but apparently it has a hard time keeping up with a slightly modified 4WD protege with half the hp. Neat.
The BG 4wd supplement to the FSM for Europe/Austrailia says the turbo hatchback comes with a rear VLSD. Which I take to mean that SOHC 4wd models and turbo sedans do not have it.1990 Protege 4WD
1 3 5
2 4 R
