Desperately need spline counts!!!
    ahh gotcha
    where did you order from before?
      just a local shop that my friend knew the owner so he gave me a discount... but they might be closing soon so i need to get these things corrected before they do
      In the Garage
      Black 93 MX-3 GS
      Bp powered
      GTR Drive Train
      The ProjectMx build thread
      MyCardomain[/SIZE]
        I recently ordered a set of 4wd protege axles and the end for the driver's side that goes into the trans is A LOT longer than the FWD axle.
        1990 Protege 4WD 5 Speed
          hmm didn't realize it is longer but makes sense... don't suppose you know the count though do you?
          In the Garage
          Black 93 MX-3 GS
          Bp powered
          GTR Drive Train
          MyCardomain[/SIZE]
            the axles happen to be out on my Protege. Some students are going to attempt to rebuild the trans. the rear output shaft and bearings are toast. It should be intresting to see what the quote to rebuild it is. My guess it is going to be cheaper to buy a gtr engine and trans over the cost of rebuilding the stock POS. Anyways. I come up with 24 splines into the diff and 26 splines on the outside. I did not see any "missing" splines. the pic did not turn out, but the left inner is huge, way longer than a FWD. Car is bone stock SOHC 4WD, 5-speed Protege.
              the missing splines can be seen if you seperate the FR axle from the intermediate shaft... the female side of that joint (cv side) has the missing splines.
                sweet.. thanks a ton dude!
                In the Garage
                Black 93 MX-3 GS
                Bp powered
                GTR Drive Train
                MyCardomain[/SIZE]
                  you rock Rivet! way to have it all setup to show. This thread is now an awesome 4WD Protege resource.
                    so i'm pretty sure that thereildeal is right that the passanger side kia axles are the same as the 4wd axles.... i just tried putting on the ones the company sent me and they are just front wheel drive protege axles
                    In the Garage
                    Black 93 MX-3 GS
                    Bp powered
                    GTR Drive Train
                    MyCardomain[/SIZE]
                      so i'm still having issues with my passenger axle, i sent it back and they are having trouble finding a correct axle since they don't make the 4wd mazda axles anymore... i'm hoping that the 1995 kia sephia axle will work and i just realized that in my first post it seems the spline counts for the 4wd protege and 1.6L mx3 are the same... is this correct?
                      In the Garage
                      Black 93 MX-3 GS
                      Bp powered
                      GTR Drive Train
                      MyCardomain[/SIZE]
                        Not sure if this helps, but on the B6T GTX, the passenger side axle between the hub and the intermediate shaft is thinner than the FWD axle. But IIRC either the awd OR fwd axle will fit there. The intermediate shaft is awd specific.
                        1991 Capri XR2 "GTXR2" BPT AWD Bastardization/conversion
                        Creator of the B6T Rocketchip
                        www.werbatfik.com
                          i think i just got more confused cause if all the AWD axles are the same then how can the b6t AWD axle be the same as a FWD axle since the FWD axle on the female side is 24 spline and the AWD female side axle is 28 spline
                          In the Garage
                          Black 93 MX-3 GS
                          Bp powered
                          GTR Drive Train
                          MyCardomain[/SIZE]
                            BF GTX != BG GTX, so just ignore what he said. you have to make hybrid axles to put a BG drivetrain into a BF.
                              so will kia sephia axles work?
                              In the Garage
                              Black 93 MX-3 GS
                              Bp powered
                              GTR Drive Train
                              MyCardomain[/SIZE]
                                kia axles have 26 spline outers, and 28 spline inners. the drivers side wont work for obvious reasons, but the passenger side might. depends if the length is correct or not.
