Has anyone used the stock downpipe from the gtx on their swap? I heard of a guy with a wagon having a problem with it hittin the motor mount, but that mighta been because it originally had a 1.9 in it?
GTX swap
The little risistor pack is for the fuel pump, it tells the fuel pump to run at a lower voltage when fuel presure isnt needed as much. You can skip this all together running the GT ecu. You only need to change two things on the stock GT harness to make it work on the BP-T motor. The FPR selinoid and 02 plugs need to be extended to reach. Other then that, start, time, and drive...JordyB
'88 Mazda 323 GTX
'91 Ford Escort BPT
So are you running the GTX injectors with the GT fuel rail? I am doing the same thing with my turboed BP, runs great with no problems at all. If you are running the GT ecu, then you should not have a problem with the fuel pump. What else do you have for engine managment?BP-05 Turbo-Sold
2004 MK4 AWP Jetta GLI
Thanks!Paul S.- New Canadian Dropzone distributor
1989 Celica Alltrac (Turbo AWD) MODDED!!
93 Escort GT- K&N, modded intake, poly-filled motor mounts, new clutch, energy suspension rear sway bar bushing set, 2 MX-3 seats, clear corners, custom 1/4" wheel spacers.
what about the knock sensor?91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
Ya a gtx ecu would be Great! , i just dont wanna pay a lot for one. All depends on price. Im on a budget, just like pretty much everyone else, lol. What is his sign in name? thanks.Last edited by 93SuperScort; 11-20-2004, 08:09 PM.Paul S.- New Canadian Dropzone distributor
OK, What size IC piping should i use? I know almost everyone is using 2.5", but with stock boost (8psi) with plans of eventually goin to 14psi i think that would be kinda big, maybe 2"? What size inlet outlet are on the VJ-20? I thought it was like 1.5"-2"?
Would 2.25 be a good compromize?Paul S.- New Canadian Dropzone distributor
^^^dont worry about my Q above i wasnt thinkin, lol^^^
Ok, i can get a safc2 for $350 cdn, is it worth it?
Can i run the gtx with just a safc with my stock gt ecu or do i need more?
All i really want is stock boost for now, but if i got a safc2 i could go above stock boost
I guess it wont work at WOT, so what do i have to do so I can not have my motor blow at WOT?Last edited by 93SuperScort; 12-15-2004, 12:06 AM.Paul S.- New Canadian Dropzone distributor
