ok thanks. it looks like i'll still be getting those parts from you D323. lol, trying to cut down costs anywhere i can...but i guess i need the stuff
ford probe GT engine into a 91 escort?
the crossmember that goes from the front radiator support back, is the same.
I got a pic of it, will post tonite. I held the v6 one up next to the one bolted on my 323, and it is identiacal from waht I can tell... I havent tried to bolt it up or anything, but I would suspect they are the same part.
The shift linkage looks the same, but as jitb said the lengths are probably different. The v6 tranny is alot bigger, and sits closer to the firewall, and is probably shorter.... It does have the same bends infront of the cat on the underside though.
Originally posted by D323the crossmember that goes from the front radiator support back, is the same.
the crossmember is the same, its just that the bolt holes on it are different b/c of the tranny mounts. AND you will need to get the upper passenger side mount off of the v6. The Bp mount goes straight, and the v6 one goes back and around.
I CANT BELIEVE I THREW AWAY THE CROSSMEMBER I HAD!!!!!!!!!!!!!!!..last time i clean up the garage...lol
yeah, he said i can have the fuel filter for free. lol. no i dont have a seriel number pic. i'll ask for one tommorow.
i figure for $200 and 120k miles its a pretty good. whats awesome is that the guy is coming up to chicago for hin on june 11th, so he said he would just drop it off1997 U-13 Nissan Altima
