i was just wondering and correct me if am wrong. should the kia axles fit on the mx3 gs transmission??
How - To: V6 Swap Guide
Originally posted by mazdapr View Posti was just wondering and correct me if am wrong. should the kia axles fit on the mx3 gs transmission??
just come up to milwaukee and have me do the swap for ya93 Escort Wagon V6-SOLD
91 Escort Wagon V6-SOLD
93 Escort Gt V6-SOLD
90 Mazda 323 SE V6-SOLD
93 Ford Ranger Splash-Its Baywatch time
i'll make the drive over too if you decide to have the swap done in MIL & we'll have a swap/meet day---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323 View Posti'll make the drive over too if you decide to have the swap done in MIL & we'll have a swap/meet day93 Escort Wagon V6-SOLD
^ yeah about that, im tired of working on the cold pavement---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
same LCA's, but there was a year change where the design was altered you want the earlier model MX3 LCA's---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323 View Post^ yeah about that, im tired of working on the cold pavement93 Escort Wagon V6-SOLD
Originally posted by bpt323 View Postsame LCA's, but there was a year change where the design was altered you want the earlier model MX3 LCA's93 Escort Wagon V6-SOLD
best way is to call Mazda and cross-check part numbers.-Jack
Originally posted by escortluver19 View Postare you sure the rs had the wider track like the gs has? every rs ive seen seems to have a skinnier track/stance to it.Maybe its just the gs rims that make up the difference
LH LCA: E016-34-350H
all years MX-3
^thanks donnie---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
just a quick question
i'll be doing my v6 swap soon enough
but the V6 MX3/Eunos Presso in NZ is expensive
but the 4cly MX3 are cheap as chips and so are BG 323's
do mx3 both have the same subframes on v6 & 4cly? so i can swap im into a 323? or is it just the v6 ones that are wider?
i understand there is can axle binding problems if i dont swap them over from a mx3?
cheers
^ the LCA's are the only wider part from the mx3. if you swap just the LCA's into your BG you'll have a slightly wider track as the BG subframe itself is a hair wider then the mx3 one.
Hit the wreckers & just grab the swap parts needed, it'll wind up significantly cheaper then sourcing a whole V6 car---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
