Dyno Results
    Originally posted by Lex
    What does your boost drop to at redline?
    Nothing, the boost stays there all the way. I think is because the boost controller that I have (Profec B). For me the best boost controller for our cars.
      I must be doing something wrong .... Mine drops to 12 psi by redline and I dont know why.
      Maybe it's a leak, maybe it's the stock EGT exhaust maybe it's the ebay boost controller.
      It's bothering me.
        It's bothering me.
        Its just the vj-20 running out of breath
          people hold 15 psi to redline though ... I talked to some local turbo techs and they believe it's the exhaust that is too restrictive
            I have 2.5" exhaust with no cat or resignator. also 2.5" intercooler piping. Still drops off at redline
              Thats exactly what I plan to run.
                What about the downpipe... is it stock?
                What does it drop down to?
                  It's bothering me.
                  I never have that problem even with out the Profec B. Overboosting well that is another history. BTW I have a 3 inch exhaust.
                    Do you have 3 inch exhaust from the turob back ... or do you have the stock downpipe?
                      i have the same setup....2.5" intake and exhaust (turbo back) and a FMIC and HKS SSQV, with the stock wastegate and no boost controller....
                      i hit 10psi by 3500ish and at about 5k if i hit WOT i will hit 15psi and stay there till redline....i have done this on 2 vj20 turbos now so i know that the turbo does NOT "run out of breath" as some people seem to think it does....
                      the boost gauge in my sig is a real shot of mine...
                      More Information
                        Its also 2.5"
                        Holds at 10-11 till about 5.5-6k then starts to drop till redline droping to about 8psi.
                          Stock downpipe. After that 3 inch.
                            But the turbo efficiency drops after 15 psi or maybe less. That's why I don’t push the VJ-20 beyond that.
                              What BOV do you run in your setup? Perhaps mine is leaking - I have the stock GTX one.
                                The best GTX I have seen on a dyno was running 12psi. 230HP on a conservative dyno, and a flat 230lb/ft of torque from below 3000 to over 5000 rpm. With a decent tune, 12psi is all you need, any more just kills the turbo quicker.
                                I don't understand the obsession with trying to run small turbos at higher and higher levels of boost???? If you want to run a lot of boost, get something like a big T3/4 hybrid, those things thrive on boost...
                                www.323gtx.co.uk
                                www.323gtr.net
