Here's a quick image I put together to show how I routed the throttle cable. Looked 100% factory.
help me settle my discussion
My ClubProtege.com Feedback Thread
MOSI Race Dynamics - Aftermarket Parts Sales & Services MOSI Race Dynamics Feedback Thread
so it only looks about 10 inches shorter than the K8 one, hmm, not to bad, just had to fab up a mounting place.
cool, thanks a lot mike.
JACK-Jack
Originally posted by Mazda_Poweredso it only looks about 10 inches shorter than the K8 one, hmm, not to bad, just had to fab up a mounting place.
JACK
Ditch the front throttle cable bracket. Mount the throttle cable on the side of the rear throttle cable bracket (there's a mounting provision that is vacant). Widen the rear throttle cable bracket for the cruise control cable, slip in and pinch it down a bit so it doesn't come loose.
Done!My ClubProtege.com Feedback Thread
awesome i know jitb just rigged his speed stuff in the tranny, what did you do mike? just installed the 1/2 line from the mx-3? if so, where's the breaking point around.
JACK-Jack
My speedo is hooked up, im just not 100% sure if i put the protege speedo gear in the tranny, or i used the mx3 one. I got to looka t it and see. But it doesnt fit perfectly inside of it, but it does go in most of th wway and does work.Last edited by jitb37; 02-17-2006, 03:32 PM.My ClubProtege.com Feedback Thread
Nice! Good to hear!My ClubProtege.com Feedback Thread
alright, thanks, that should help!!
jitb, do you have the horz crossmember hooked up?
JACK-Jack
ok, so i'll pick that up at the wreckers too, i didnt know if it bolted in or not. thanks
JACK-Jack
