bolting it in is one thing. wiring that thing up...goodluck. i hope to see it running soon. nice work!
bp into a 2nd gen
Almost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms sideskirts... check
ms rear skirts... check
ms spoiler... check
ms struts... check
Still trying for a bp swap..:
hey good luck and post lots of pics.
Mods:
kinda pricey---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
so i made a top tranny mount out of both the 97 pro(rubber part that mounts to the body) and the egt(the part that goes through the rubber and bolts to the tranny). the full egt mount fit but sat about 1" lower in the engine bay and almost laid on the crossmember support. the 97 one brought it up.
ok have another big prob my fuse box on the 97pro1.5 has a 4pin connector goin to it...but on the 91 bp harness its a different 3pin .....looks like im gonna have some fun tryin to fig this out.
for u guys that did the 1st gen to 2nd gen swap what did u do??
this is the only thing that might make me put this in my 93 323 if i cant fig it out.
the three wires that go to the fuse box on the BP are +12v switched, ground, and a purple wire whose function i do not know.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
patrick(project323) would have little input anyway. he wasn't really the diy'er when it came to his swap, meaning - he paid people(corksport) to do the swap. and he used hatlech for the engine management.Almost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms spoiler... check
ms struts... check
call & ask CS---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
good luck with ur 2nd gen u should have just bought a us bp out of the 95-98 es protege it has 122 hp 117 tqe and u could have still used the vj11 turbo setup and saved tons of money i have a 2nd gen with the es motor but got tired of the car in trying 2 get it boosted so i just dropped the idea sold the car and got a 1st gen 323 se hatchback which i have on boost now
hey wats up man i feel ur pain trust me i had a vision of wat ur doing now myself i own a 2nd gen 4 6 yrs set it up with the mazdaspeed exterior i even did the z5 swap 2 bp es 95-98 us motor that wat motor u should have gone with remember u have obd2 setup from the 95 model and up plus u also have map sensor which is perfect 4 doing super safc II fuel controller setup 2 tune ur boosted motor if u have any question on doing ur swap ask me i know alot about 2nd gens but sold mine and got a 1st gen 323 se hatchback check it out on my profile i have plenty of pics
