hey wats up man i feel ur pain trust me i had a vision of wat ur doing now myself i own a 2nd gen 4 6 yrs set it up with the mazdaspeed exterior i even did the z5 swap 2 bp es 95-98 us motor that wat motor u should have gone with remember u have obd2 setup from the 95 model and up plus u also have map sensor which is perfect 4 doing super safc II fuel controller setup 2 tune ur boosted motor if u have any question on doing ur swap ask me i know alot about 2nd gens but sold mine and got a 1st gen 323 se hatchback check it out on my profile i have plenty of pics
sorry not making fun ... but do you breath when you type that? That was hard to read! Punctuation my friend
im just waitin for the mega squirt to come in....and i think i am gonna go back to the '971.5 harness and just use the '91 connectors....so i dont have to play with the cluster much or the ecu.
if you are going with MS.. arent you getting rid of the stock ECU?
i'd modify the 91 engine harness and add to it the dash plugs that you might need for the tach or idiot lights.
I have a 95 protege and i have done a bp swap its not easy im now going MegaSquirt in a few weeks i have a guy that does it cheap in Florida and tune's it also im look for 400hp
coming soon
i think i just need to get a egt one and drill the holes in the crossmember for the mount to bolt to.
also i sold the vj20 and bought a garrett t3/t4 and in the process of makin a adapter flange to bolt a d16 honda turbo manny so i have the external wastegate...which is a tial38mm.
