N/A ECU w/ SAFC & 550cc????
    he also blew engines running it like that
      Well, It is either your engine or your tranny.... And since I can get another used BP with under 100k for $150 I will go engine :D
      Mexican: "You wanna race for titles?"
      Mormon: "lol, no, I don't want your car."
        he also beat on it daily.
        5 boosted bp cars,why...
          yea but cheeping out on management is just asking for it
            They were on stock Na ecu and 550's running pig rich with a crappy idle but rich in boost and cruising. I pm'd him asking his setup and how it ran so great. Just keeping things rich made it so it didn't blow up.
            "Who Dey"
              Well, didn't get the 550s in time... so I will come back to this in a couple weeks. There will hopefully be another dyno day....
                Got the 550s in and I idle at 14:7-15:1 and driving around not in boost at 14:7-14:3:1 up until the ecu flips the "vics" on at like ~5300rpm, then it goes to like 11.5-12:1.... But still runs great!
                Finally! Post 1700!!!
                  whats your safc maps look like with 550's? also are you still running the safc off a map sensor?
                    yes, but until I figure out the fuel issue I won't post the map... It does do great though at a cruise, maybe a tad rich, but fine.
                      so whats the setup gtx ecu 550cc safc w/map ?
                        He's running a n/a ecu
                          i thought he switched it to a gtx i know the title said n/a
                            regardless of your AFR, the n/a ecu runs way too much ignition advance. i got well over 300whp out of my 550's with something like 15* advance at full boost. if you try to run that much power with the n/a ignition map your rods are going to try to escape from the block
                              i think it would be safer to run a bp26 ecu over bp09 bp10 ecu's
                                any updates?
