So I'm planning to jump aboard the Megasquirt train and go standalone. The problem I've noticed, though, is that there are certain features on the BP/car in general that megasquirt cannot control (or that i'm not sure if it can control).
So my questions are:
1. Do you guys still use VICS with MS?
2. Can megasquirt control the a/c? How about the Idle air?
Anything else that I should worry about when going standalone?
I'm pretty familiar with the ECU. Not too worried about figuring out which wire is which... just not sure about the tuning end of megasquirt. I have heard that the base map on MS can run the BP fairly well, but I just need to know what would all be needed for things like the A/C, IAC (I really don't feel like making an IAC blockoff plate and would rather retain the IAC), and VICS..
Thanks guys!!
Thanks guys!!
