Has ne one ever tried using a vafc and if so what do you set the sensor numbers to? it dont let me choose the sensor type but it will let me set the number thats it ik for a safc you use the flap sensor and the number 7 i got one for free so i figured i would try it
vafc?
^ indeed
vafc has less resolution for adjustments vs the safc
Originally posted by bomkamp6 View Postim running 460cc injectors with t3 turbo off a svt mustang
230hp is very doable with GTX goods using a T3 and some 460cc injectors, I should know
