Exactly, Why buy a GTR motor if your not gonna run that bitch balls to the wall. i think theres 2 ways to go . GTX swap with gtx ecu and quality parts for a good daily driver/racer good for 200 hp. Or GTR motor with a haltech and all the goodeis to push 300 plus whp. If your gonan run the vj-23 atleast run it faster than the vj-20. And yes the GTX is faster than the GTR in stock trim quarter mile
Is $5000 enough for a GTR swap?
Originally posted by itzkcatz
Exactly, Why buy a GTR motor if your not gonna run that bitch balls to the wall. i think theres 2 ways to go . GTX swap with gtx ecu and quality parts for a good daily driver/racer good for 200 hp. Or GTR motor with a haltech and all the goodeis to push 300 plus whp. If your gonan run the vj-23 atleast run it faster than the vj-20. And yes the GTX is faster than the GTR in stock trim quarter mile2006 Mazda 3 hatchback manual
Originally posted by Protoss
WTF you dont NEED a EMS!!
Invest in the GTR/GTX ECU. there 700 bucks at corksport. **** a $1300 EMS! you dont need it unless you are going for a track car.
And what are your plans? FMIC? stock? 180whp? daily driver/ track car???
you got to be more specfic here"Never run out of real estate, traction & ideas at the same time"
-93 MR2, 129 ES
ClubProtege.com Tech Articles
My plans for the car would be a semi-reliable mid 14 second car (up here at 7800 ft). Id like a FMIC, I have a Pakfeifer (sp) front bumper here that should fit with a lil mods. As far as dropping the engine, my garage is in use right now by my other project car (66 Nova) and I dont want to drop an engine in the street because I live on a pretty busy street, and Im sure my neighbors would call the police on me for some retarded reason, so that would be a bigger hassle. I suppose I could use a friends garage. I think my best bet though would be to get a whole front clip as then I would have just about everything i need including all the little stuff, (oil lines and such). Do they sell GTR front clips?? Are the stock downpipes from a gtx good quality, or would I be better off getting a custom one made. Thanks!Eat ****.
Originally posted by 91ProtegeLX
My plans for the car would be a semi-reliable mid 14 second car (up here at 7800 ft). Id like a FMIC, I have a Pakfeifer (sp) front bumper here that should fit with a lil mods. As far as dropping the engine, my garage is in use right now by my other project car (66 Nova) and I dont want to drop an engine in the street because I live on a pretty busy street, and Im sure my neighbors would call the police on me for some retarded reason, so that would be a bigger hassle. I suppose I could use a friends garage. I think my best bet though would be to get a whole front clip as then I would have just about everything i need including all the little stuff, (oil lines and such). Do they sell GTR front clips?? Are the stock downpipes from a gtx good quality, or would I be better off getting a custom one made. Thanks!-Robert
'93 Protege Turbo LX 5-speed
-GTX VJ-20 turbo w/ custom downpipe, Haltech E6K Kit w/ 3Bar MAP sensor & O2 sensor (Engine Management System), .040 overbored pistons with slightly raised compression, Resurfaced cylinder head & valve job, GReddy Type-S BOV, Turbo XS boost controller, 450cc injectors, Walbro 255lph fuel pump, 22"x9"x3" FMIC, full 3" exhaust w/ Catco Catylic converter & Summit Turbo Muffler, ACT Clutch Kit (stage 2), Uretheane shifter bushing, Triple Gauge Pod w/ Boost, Air/Fuel Ratio, and Oil Pressure gauges, Falken Azenis Sport 195/60HR14 tires on steelies.
don't waste your time with a GTR motor if you only want to run 14s, even at altitude.
get a GTX engine if you're set on swapping a motor...otherwise, buy a manifold and snail and get to work."Never run out of real estate, traction & ideas at the same time"
-93 MR2, 129 ES
Ohh, im not saying that I just want to run 14s. I was just using that as reference. Once I start going fast Ill want to go faster. 14 was just a short term goal. If I could Id like to make my car run 10s!! LOL, but thats not daily driver friendly. Im thinking of just using my other BP motor instead of buying a GTR or GTX, i bet I could turbo it for way less that 5k! Where can I get a VJ20 or 23 turbo and manifold from? Corksport?? Thanks!Eat ****.
Ohh, im not saying that I just want to run 14s. I was just using that as reference. Once I start going fast Ill want to go faster. 14 was just a short term goal. If I could Id like to make my car run 10s!! LOL, but thats not daily driver friendly. Im thinking of just using my other BP motor instead of buying a GTR or GTX, i bet I could turbo it for way less that 5k! Where can I get a VJ20 or 23 turbo and manifold from? Corksport?? Thanks!-Robert
Ohh, im not saying that I just want to run 14s. I was just using that as reference. Once I start going fast Ill want to go faster. 14 was just a short term goal. If I could Id like to make my car run 10s!! LOL, but thats not daily driver friendly. Im thinking of just using my other BP motor instead of buying a GTR or GTX, i bet I could turbo it for way less that 5k! Where can I get a VJ20 or 23 turbo and manifold from? Corksport?? Thanks!"Never run out of real estate, traction & ideas at the same time"
-93 MR2, 129 ES
Originally posted by turboge
$5000 is enough to build a N/A BP into a 400whp beast.-Robert
