as soon as i can get the cranking settings right on the megasquirt. i was up until 4 AM trying to get it started... and this morning i woke up and it was raining, and its been raining since. i'm glad i decided to toss a tarp over the front of the car last night!
GTR custom DP
i dont know, i tried starting with really low cranking PW's and moving up, but it never seems to catch... and when i pull the plugs they are soaked. i know i have spark because i set the timing with a timing light while cranking.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
With the PW I gave you, you should be good for starting. You can even deviate from those quite a bit and the car will still start or catch.
So your timing is correct I assume? In that case make sure your dwell for spark is set right and that you are sparking every 180 degrees (use the distributor settings for spark)
Also make sure you set your cranking RPM around 200-300.
Deflood the engine if it's flooded by holding your foot on the floor and cranking.
Also, don't forget your GTR injectors are peak and hold (low imp) so the injector settings must be changed from what mine are at or you have to use a resistor box.
After all this fun, do an oil change as you probably have lots of fuel in there and keep your battery on a charger - I killed mine trying to start.
lex do you have aim or anything so i can talk to you about this?
timing is at 8* while cranking. ive moved it up and down from that but it acts the same.
the disty settings should be right, because i based this from the MSQ of a bp that was running just fine
ive got the Pwm settings for the injectors set upEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
here are some pics of the car/downpipe
damn you for teasing me with these pictures! i want to go for a ride in it---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by therieldeal View Postlex do you have aim or anything so i can talk to you about this?
i am on msn but it says you are offlineEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
I don't usually cus but DAMN THAT **** IS ****IN HOT jon1993 Protege LX-Midnight's shadow SOLD
haha if i can ever get it running i will!
i need your address still so i can send you the rest of the moolahEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
