From my looking around, it would be cheaper to buy a BP-T, and used BP is around 300-400 and the manifold for a 16g was qouted at 300 while the turbo itself was 600. Im thinking the BP-T would be the less complicated and worry free way to go since so many people have done it, from there you can always get a bigger turbo. Screw the negative comments, you want more power just like most people do.
is the cheapest way to turbocharge...
It's not about being negative, but realistic. So many people on here seem to think that they can have a fast turbo car for under $1K. They fail to realize that there's much more than just the turbo and manifold for a proper setup.-------------------------
'91 LX
'03 Mazdaspeed Protege #235
^^ exactly. im not trying to start any ****, i mean, who doesn't want to go fast. but turboing a car for a 1000 or less, reliably is kinda unheard of. he's not an auto crosser, but, suspension and brakes should be thought of as well. good luck in whatever he does, but overall, a gtx engine is the best choice imo.i hate being broke!
Originally posted by 1990DXoh and ne3k, i totally agree, without more power its pointless upgrading the rest
I don't agree with that..ask anyone that is autocrossing on a stock engine with an upgraded suspension if it was pointless for them to "upgrade the rest."2000 DX, Blue
Eibach Pro-Kit, MSP Struts, 16" Kosei's on Honkook Ventus HR-II's(205-45-16), MSP Exhaust, Injen CAI, MSP Strut Tower Bar, NGK Wires
2 JL Audio 10w3-d4's in a sealed box, Rockford 500s amp, 2 6x9 Pioneer Premier 4-ways, 2 6x8 Kenwood Excelon 3-ways, Rockford 301x amp, Pioneer Premier DEH-P650, Dynamat in some fun places.....
Originally posted by Tweeaksoh also I know someone w/ the BPT in their pro....just the motor swap stock LX ecu fuel pump etc... and is haveing no problems running whatever the VJ-20's wastegate is set at.
And MAtt, i forgot about suspension lol, it's true my car is a sloppy sally and it needs some work done anything over 70 this thing feels horrible as well. But brakes, totally un needed for a LONG time.00 dakota 4x4
90 crx si - ls/vtec
so at 4psi what are the hp gains? (roughly)
also, the 1300 only covers parts right? (i probably would need to pay to get this stuff installed unless you all think a n00b like me can do it)
and just to re-iterate, i only need the turbo, pipes, and a front mount inter cooler? (no bov, new fuel system, ecu, etc.)
as of late, i've really become interested in dropping a turbo into my car.Tag Team
its not absolutely necessary to have a BOV, but its a very good idea. I wouldn't boost mine without one...
If you wanna run 4 psi, then you're gonna need an external adjustable wastegate. That alone will run you about 2 bills. About how much power it'll make all depends on what turbo you're running. A bigger turbo can produce higher hp w/ less boost then a smaller one. It depends on the CFMs of the turbo.
im down ive got a couple of weapons we can use....Im trying to get me an assualt shotgun (heard of a striker 12) here in a little bit. Damn guns draining all of my car money. I just picked up a S&W 357 Magnum six shooter, boy is it nice.
Anyway like I said I'll rob a bank with you. We will shoot the gaurds tell the hostages we will then and well not during but after. Then we will
