Originally posted by Vash00es
my EGT vs an 87 rx-7 351 small block
Originally posted by Tazman2And this is why v8 swaps in a rx7 are St00pid! Got owned by a EGT in the twisties AND on the straight away! Dumb domestic ricers!One day you are born,
The next big milestone
you discover go zoom-zoom
you can't get enough!
Remember, when someone annoys you, it takes 42 muscles in your face to frown, BUT, it only takes 4 muscles to extend your arm and bitch-slap that mother@#?!&! upside the head!!!
This car refuses to die! By TheMAN
Originally posted by Tazman2Sorry its nothing personal i just don't like big motors with their ego enhancing properties. Ever see the sti vs c5 video? The c5 owner wanted to race and lost to the sti and proceeded to snap and punch the sti owner in the face! hahah. Sorry but thats just how the v8 crowd is around here too but then again all the honduh ricers are the same way but thats awhole different level of stupidity all together! So yeah i lost my point as i just woke up and i need to eat!Joe H
2000 Chevy Impala
3400 3.4 Liter V6
Fun Times
Fenderwell Intake w/ K&N Cone,
U-Bend Delete, Resonator Delete,
Flowmaster 40, Hi-Flow Cat, Optima Redtop
Originally posted by Vash00esYes, again i posted that video on this forum awile back, along with the lingenfelter vs dsm video**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods! **SOLD**
I did a little bit of research about weight and center of gravity with a LS1 swap.
...how much will all this V-8 stuff weigh down my car ?...
...the finished weight depends on a lot of variables when opting for a Chevy drivetrain. Component choices can vary widely.
Bill Hagen's '94, equipped with a Camaro LT1 (factory equipped with aluminum heads), T56 6spd, AC, PS, oil cooler, cast iron exhaust manifolds and catylitic converter weighs in at 2950lbs with a half tank of fuel, and 50lbs added to the spare tire well. The 50 lbs in the tire well brought the balance to a perfect 50/50 (1475 front / 1475 rear) weight distribution with the 1/2 tank of fuel. This car could also be trimmed out by simply filling up the fuel tank!
Retaining the RX-7's near perfect weight distribution isn't a big problem, but the job is even easier if you build the new powertrain with balance in mind when choosing/relocating components. The Chevy engine is heavier than the rotary, but by the time you consider all the rotary specific components you will also remove, the gain is minimal. Solenoids/relays, heat shields, oil coolers, turbos, intercooler, etc. If the final balance needs fine tuning, it's easy to add a small amount of weight to the extreme rear of the car to trim it out. Some 1st & 2nd gen RX-7 V-8 conversions have achieved 50/50 balance by just removing/relocating components and deleting the AC. Considering that the 3rd gen also has turbos and an IC to remove, achieving balance is a piece of cake.
consider this.... If you look at the weight gain from a power/weight stand point, it's easy to realize that you can add some weight as long as you back it up with enough added power. The RX-7 is the lightest car in it's class, and even with a V-8 swap, you're still going be much lighter than the competition.
...won't a V-8 have a higher center of gravity than a rotary ?...
......Another parameter typically debated "rotary vs. V-8" is CG height. Many believe the V-8 with it's higher heads and intake manifold raise the CG height and must ruin the handling. Our response is that things are not as they may seem. The engine/trans should be considered as a package. The rotary's appx 6" higher eccentric shaft centerline and resulting higher transmission location all but eliminates any advantage the smaller rotary engine is thought to benefit from. We doubt the CG of the engine/trans package, as installed in an RX-7, is that different. An LS1, with it's aluminum block, aluminum heads, and plastic intake manifold, may even have an advantage over the rotary with regards to CG height.
Rotory's are cool and 'unique', but it's just my opinion that an LS1 FD would be cooler and MORE unique. I like 'muscle cars', but they all have tradeoffs. The designs are butch and ugly, the interiors / fit and finish are garbage, they weigh a lot, and they aren't the greatest around the bends. Japanese cars are often the exact opposites of this... Why not combine the brute force of a high-displacement engine and put it in a sexy, great handling car? It's the best of both worlds.Dan
dreesemonkey
On the RX-8 handling note, yes they do handle very well, I watched a race between a Race-prep 2005 Mustang GT, and a race-prep 2005 Rx-8 at Laguna seca between the main-events. They were driven by two of the people that take you around the track if you pay I think $20 bucks a lap or something. The RX-8 ate the mustang through the turns, especially the last turn, but the mustang returned the favor through the straight-er parts of the track. At the end the mustang only pulled ahead by less than half a sec I think, he jumped on the RX-8 after the last turn and through the straight. When you drive one though they still feel slow, and the unimpressive gas mileage is a big issue for me on the street. If i'm going to pull down 17mpg, than I want a car that can at least pull more than a 14.4 in the 1/4. The 350Z is faster, and gets better MPG, but it's also a french nissan, stupid renault
For whoever says muscle cars suck
The name escapes me atm, but i know there is a classic muscle car ( 60's era i believe ) that weighed almost 10 thousand pounds, and had 400 something HP, and still pulled a 0 - 60 in the 5 second range, try that with any of these modern day car engines in a car that weighs 10KJoe H
2000 Chevy Impala
3400 3.4 Liter V6
Fun Times
the amount of misinformation is beyond repair.....no paragraph or link can fix it.
WORST THREAD EV4r
All i can say is a v8 swap in imports doesnt ruin the handling characteristics. it changes but it doesnt ruin it. most of them get better. i know the ls1 miata wwight balance improved with the swap.
Originally posted by jitb37the amount of misinformation is beyond repair.....no paragraph or link can fix it.
WORST THREAD EV4r
All i can say is a v8 swap in imports doesnt ruin the handling characteristics. it changes but it doesnt ruin it. most of them get better. i know the ls1 miata wwight balance improved with the swap.Dan
dreesemonkey
Ive always wanted to see what i could do with the old Toyota MR2s.... I love Midengined cars, and im sure they have great handling potential because of that.. now if i could only get more power outta em!Joe H
2000 Chevy Impala
3400 3.4 Liter V6
Fun Times
Originally posted by Vash00esIve always wanted to see what i could do with the old Toyota MR2s.... I love Midengined cars, and im sure they have great handling potential because of that.. now if i could only get more power outta em!sigpic
92 240SX: KA/T25, nerd mobile
Originally posted by swalltr207jgwhen I say track, I mean road corse, or autocross, or basically a track with turns. As far as straight line performance everyone knows that the rx8's arn't BLAZING fast in the straights, but it wasnt made to be a drag car, more a road corse car hence something with turns. As far as an rx with an ls1 handling better than one with a rotary, thats kind of a double negative, cause once you remove the rotary its no longer an RX (rotary Experiment) But I find it hard to believe that any RX bodied car with an ls1 in it could out handle the RX with the rotary in it given that the suspension hasnt been changed on either vehicle. If it has well thats like comparing apples and oranges. As far as an ls1 RX bodied car being faster in the straights than an Rotary, duh , what r they like almost 500 hp stock. I'll say this, the RX cars werent designed with drag racing in mind , why do you think mazda puts the exact same motor in their f1 cars, Hmmmm think about it balance, weight. And as far as longevity/reliablility of the rotary, most full race rotarys can go a whole season without being tore down to fix or change anything, as long as you know how to take care of them (yes they need oil) they can last a really long time. And dont say what about the fd3s because everyone knows it had COOLING issues.1999 SVT Cobra Black/Black
2003 Mustang GT DSG/Black
Thats because you only know of douchebags... I raced a 2nd gen prelude and the guy stayed close to me all the way. I was in my GT... granted it didnt downshift and its not the quickest thing from a roll since its an auto... still. I completely ate him up from a dead stop but I still gave the guy a thumbs up for keeping up from a roll.
I did race some assholes in an STi. They kept talking crap and I didnt really want to get beat since it was going to be from a dead stop but I raced them anyways... turns out the guy sucked and I walked him bad. Again this was in my GT.
**** talkers are in all cars.... In short " Quit hatin' "1999 SVT Cobra Black/Black
