Reccomendations on rim/tire choice.
    15 inch
      205/50-15 or 205/55-15
      Both of these sizes are recommended for a rim width size range of 5.5" to 7.5". Nothing wider is recommended for a 5.5" rim.
      Reference:
      21st Century Performance by Julian Edgar; Recommended Rim Widths, page 282.
        Thanks goldstar. My rims originally came with a 185/60/R15 tire. If I run smaller profile tires, my speedo/odo will not longer be accurate and my gearing will seem even shorter Is this something that one should do, or should I just get larger rims and smaller profile tires at that point?
          I went to: www.miata.net/garage/tirecalc.html
          Compared with stock 185/60-15
          205/50-15 gives speedo reading 2,8% too fast (60 is actually 58.3)
          205/55-15 gives speedo reading .6% too slow (60 is actually 60.3)
            Hm... unless I am missing something here, both sizes should give the speedo a reading that is too fast since they both result in a wheel that has a small diameter
              185/60-15: diameter = 23.7"
              205/50-15: diameter = 23.1"
              205/55-15: diameter = 23.9"
                I stand corrected - thanks a lot for the info
                  Glad I could help.
                  Happy Motoring!
