i was just wondering if there were any real advantages of getting 16x7's instead of 16x6.5's. I was looking at wheels and for a set of 4, 16x7's are $70 more.
16x6.5 vs 16x7
only weak tit's need powersteeringPlus, rim width has nothign to do with turning resistance. only the tire does.
the wider rim means bette fitment of the tire with less rollover of the sidewall.
as most tires 205 & such are designed around a 6.5" rim which is retarded.
thats my take.
get some more of the tire guru's in here to help you---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
not always---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
most rims are 16x7 so whats that tell you---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by me19875 View Postok, i kinda figured it would make the tire wider and handle a little better, but is it enough to justify the extra $70?
