I have some questions, i know it’s been asked before but i can’t seem to find it. Been searching for a few hours. I got a Klde motor from a 93-97 Mazda 626. And i would like to swap it into my 91 Mazda 323. What do i need to make it work as in tranny, ecu, engine wire harness, etc. I’m excited to do this project, i see a lot of people have done it but i cant find the info i need.
Need help on Klde swap
I recently did a KLZE into a 323. I used:
KL motor
MX3 front subframe and suspension/steering (mx3 rack is quicker ratio, the mx3 axles are a wider track width than the 323, so using the hubs/arms will push everything out the required amount, swapping entire subframe is easier.)(also swapped rear for disk brakes)
MX3 V6 engine harness
MX6 ECU with custom fuel maps (custom needed for KLZE, not KLDE, but I would suggest sticking with a 2.5L ecu, not the 1.8MX3 ecu, as the 1.8L ecu only has one timing map whereas the 2.5 has both a high and low octane map. All the K series ECUs will plug in and run in all the K engine harnesses, the only difference is the early models used an additional coolant sensor.)
MX3 V6 motor mounts including bolt on top left sheetmetal mount to body
MX3 brake booster and master cyl, unless you use a remote reservoir. There are some BMW 2002 remote res. fittings you can use as well.
Dodge Neon radiator.
I was documenting my swap on another site, but dumped a copy of the thread here: https://foxed.ca/323/323.html I have not finished writing everything up or editing, but the info should be there.Last edited by SgtFox; 05-29-2019, 08:07 PM.
Welcome. Makes me happy to see people still working on these old things.1990 Protege 4WD
1 3 5
2 4 R
Originally posted by SgtFox View PostI recently did a KLZE into a 323. I used:
KL motor
