As long as the diff pin is welded you'll be fine. Thats the first thing to go on the diff.
Pommyvince's BF 323 KL ZE swap
Only illegal in NZ to weld up the diff so that its locked ie. lock up the spider gears so you have a fixed axle. If you are just welding pin in to retain it it shouldn't be a problem.
Got a price on making new driveshafts to my pattern...$725 inc taxes (NZD)....which is not toooooooo bad but will have to wait until end of January to get them by the time they have been hardened/heat treated.
you and your buttery ass swap!...kind of want to get another 1st gen and v6 itb that hoeOriginally posted by 90prtegehave you heard a yaris drive by you??? it says immmmmmmmmmmmmmmmmmmmmmmmgayyyyyyyyy!!!!Originally posted by TurproFk the family. Drugs and hookers take priority first
bpt323: broom break
CRZbrussian: that sux
CRZbrussian: get swifer wet
CRZbrussian: ****s aluminum
Something got lost in translation there but wish I had the money for ITB's.
Frustrating day yesterday looking for suitable struts. I finally have some Laser TX3 turbo assemblies with 260 mm discs which came with bonus Monroe gas struts.
Anyone know of a good brake upgrade other than the Galant VR4 discs??? I already have some 22V calipers.
I'll get some pics up as soon as I have sorted my daily driver which **** a rear wheel bearing yesterday.
Motor came from an Mazda Efini MS8 which there are quite a few of cheap here as the vast majority of cars in NZ are secondhand imports from Japan.
Progress has ground to halt while waiting on a drive flange for my other car .......not due to tuesday and making life difficult as I live out of the city.
In the meantime I might see if the 626 discs will fit the TX3 hubs. 626 the same diameter but 3 or 4mm thicker.
Not much to report at the moment.....Engineer has my dummy driveshafts to copy and they should be a couple of weeks away. In the menatime I have finished the exhaust and made a start on the wiring. I now have start and chrage but not much else.
I am going to convert my suspension to coil over ( 626 springs do not clear the strut tower). Does anyone have any experience with the Arospeed kits that are available. Any feedback appreciated.
Originally posted by Pommyvince View PostNot much to report at the moment.....Engineer has my dummy driveshafts to copy and they should be a couple of weeks away. In the menatime I have finished the exhaust and made a start on the wiring. I now have start and chrage but not much else.
I am going to convert my suspension to coil over ( 626 springs do not clear the strut tower). Does anyone have any experience with the Arospeed kits that are available. Any feedback appreciated.FE3 POWA1985 Mazda 323 BF5P - FE3 powered
But the coil overs for BG struts might fit BF struts......if they are 41mm diameter bodies I reckon you might be able to adapt a BG kit to BF...cheaper than getting them custom made. Check out www.customstreetdesigns.com as they seem to carry a good range.
Originally posted by Pommyvince View PostMotor came from an Mazda Efini MS8 which there are quite a few of cheap here as the vast majority of cars in NZ are secondhand imports from Japan.
and if you can, tell what the car is over in the states, lol. sorry if im asking for a lot, im getting so fed up with these issues.
'88 323 sedan, K-swapped..
I can understand your frustration !!! I was using 626 BC model..the very first front wheel drive 626 ( mid 80's) so that I got bigger CV's and thicker 260mm discs and bigger calipers but the springs will not clear in the strut tower. I then tried Ford Laser TX3 turbo so that the springs would fit in the strut tower..CV's would be the same as you have already....but discs are thinner than 626 ones. I am now back to the 626 stuts which have the bigger CV etc and 18mm stud in lower ball joint plus using MX3 tie rod ends (bigger stud). With me so far ??? So, now looking for a coil over kit so I can get the strut in the tower.
Hope that all makes sense ?? Confuses me at times lol
One last thing... I have machined a 15mm long and 15 diameter shoulder on the top of the 626 strut so that I can use the BF 323 top mount.
Unless you attempt to fit 5 stud hubs from 626/MS8(maybe probe) you won't get anything with same diameter shafts. 626 BC model was the biggest I could find with a stronger but similar hub to the BF 323..............................think I'll go and have a lie down now lol.
