Hope you get the issues taken care of quickly and easily. Good luck.
It's Arrived!
Alright, I worked on the GT a bit after work today. Changed the charge lines that were held together with tape, changed the throttle position sensor, as I was getting code 12 on the CEL, and cleaned it up a bit. The tps fixed my lean issue and CEL is gone, my idle is still really low though, and the temp gauge is barely coming up at all. Have lots of heat through the vents though.
Also, and this is my biggest concern, the previous owner disconnected the wastegate actuator pressure line completely. The car has a brand new K&N cone filter, and a full 2.5" exhaust. It's only boosting to about 7 PSI. I thought it would be due to the tape covered lines, but even with the new ones, it's the same. Is my turbo pooched, or should I keep looking for boost leaks?Last edited by DuRWooD; 05-13-2011, 08:52 PM.sigpic
1992 Familia GT-X
1988 323 GTX
2011 F150 Lariat Ecoboost
2014 Civic Touring
First oil change on the GT today. I've put about 500km on it since I bought it. Oil was BLACK! Arg, I hope this engine is in good shape. It's going for an e-test tomorrow morning, I'm doubtful it will pass. Wish me luck. I only have until the end of the week to get it safetied and e-tested before my 10 day permit runs out.
Also, filled it with fuel today, 8.32 L/100 Km, 28.3 MPG. Have not been driving it nicely eitherLast edited by DuRWooD; 05-15-2011, 07:34 PM.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
Well, I failed every category of the e-test except CO% at idle, which barely squeaked by. So, I took it to my favourite exhaust shop, got a new 2.5" high flow cat welded in, took it back for a re-test and passed with flying colours!
Took a look underneath while it was on the hoist, very nice shape overall. Noticed as well that it has a 2.5" stainless down pipe, stainless brake hoses, some sort of silver after market struts, and red lowering springs. Very nice
Repairing some trivial things this afternoon in preparation for my safety check. The hood latch cable is broken, which is a safety item. Does anyone know if hood pins plus the secondary latch would pass safety?
Originally posted by heinze.ketchum View PostYeah fuel economy! Good luck on the e-test, can't wait to see the car this weekend!Last edited by DuRWooD; 05-16-2011, 04:48 PM.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
Possible the boost gauge is pooched? Or does it feel like it's only boosting 7psi?
When I bought the Subaru, it was only showing at 8psi. Felt fast, but the gauge said no. Otto's Subaru told me it's seeing about .01 mPa of boost, which is what is should be. My gauge just sucks.sigpic
2004 Subaru WRX STi
2003 Toyota Highlander
Originally posted by Yoda View PostPossible the boost gauge is pooched? Or does it feel like it's only boosting 7psi?
I'm fairly sure the gauge is accurate, It should be hitting the fuel cut with the mods it has. It's quick, but I've never driven one before, so it's hard to say. It is however very laggy, hits positive boost almost instantly, but to build to 7 or 8 pounds takes a long while, longer than any turbo car I've driven.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
Going for my safety tomorrow. I'm worried it'll fail because it has no power steering. The two piece pulley on the crank shaft is now only one piece, so there's no where for a belt to go. That, and only one rear wheel e-brake works. Oh well, we'll see. If it doesn't pass, the 10 day will expire before I can fix it, and I'll have to get it towed.
Edit: Going to pull the power steering, and a rear caliper from the GTX to pass...Last edited by DuRWooD; 05-18-2011, 04:11 PM.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
Thanks, but I was just looking through my box of spares, and there is a brand new pulley and brand new belt in it. I guess the previous owner had planned on putting the power steering back on. What I really need is two new rear calipers, neither my GT or GTX have working e brakes due to the calipers.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
I don't know of a good import part place in Belleville, but I would give Mike at Import Auto Supply here in Kingston a try. Otherwise, www.rockauto.com has them for $96 Canadian. All my spare calipers need a rebuild at the very least.1988 323 GTX
2009 Mazda 5
Originally posted by J.P. View PostI don't know of a good import part place in Belleville, but I would give Mike at Import Auto Supply here in Kingston a try. Otherwise, www.rockauto.com has them for $96 Canadian. All my spare calipers need a rebuild at the very least.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
Well, I'm getting a bit agitated, I took the GT to the garage to get a safety certificate a week ago today. If failed, but it was just a tie rod end that it failed, don't know how I missed that one. Anyway, they said they could have a new one that afternoon... It's now been a week, they keep getting the wrong part. I want to be driving this thing.
Anyone else have problems with the wrong part for these cars? I assume their database just didn't have the GT model or something. I went through a similar problem with my BMW when I got calipers last, ordered some, got them home, painted them black, went to install... wrong calipers... 3 times in a row.
That's my rant. Rare, oldish cars are a pain.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
Odd - I understood the GT ones were the same as any other 323 of that age. Have you compared the ones on the GTX?
There are a ton of bad cross-references for the GT & GTX. I lost count how many shops said "No problem" when I ordered a rad for my GTX - not a single one was correct.Last edited by J.P.; 05-27-2011, 08:59 PM.1988 323 GTX
2009 Mazda 5
Originally posted by J.P. View PostOdd - I understood the GT ones were the same as any other 323 of that age. Have you compared the ones on the GTX?
I did talk to the garage today, and they said they had ordered it from the dealer using the VIN, so we'll see how that goes.sigpic
1992 Familia GT-X
1988 323 GTX
2014 Civic Touring
