go to my car domain http://www.cardomain.com/ride/2266443/3 the first pic on this page shows the rear stud that i replaced. click on it for a better close up. i will find a shot of my front as soon as i can. probably not until at least thursday because i have night classes monday thru wednesday
Complete AC Removal
It looks to be the Drivers side you replaced? If so, how did you get it to drop in from the top?, there is no access to it from anywhere, unless you take off the whole plate they are mounted to.
Or did you drill it out tap it and run a stud in with some lock-tite? This may be the route I'll go, taking the whole plate off seems a bit further than I need to go.
i didnt drop it in from the top i had the whole sub frame out because of another bolt that broke on me. so i flipped it upside down and drilled it out and welded a new bolt in. you can do that from underneathe the car if you want. it is much more sturdy than any lock tight setup you put on there.
92 GT GTX Autox machine Dead and gone
98 ZX2 Currently rusty Need a new car
I'll have to do it from underneath, to pull out the subframe I'd have to pull the motor out and that is still in the car. As for welding in the new ones I don't think anyone I know has a portable welder. I'll have to tap them run some studs with locktite temporarily, and then I can tack them in at my buddys' shop.
Originally posted by 91scortgtI'll have to do it from underneath, to pull out the subframe I'd have to pull the motor out and that is still in the car. As for welding in the new ones I don't think anyone I know has a portable welder. I'll have to tap them run some studs with locktite temporarily, and then I can tack them in at my buddys' shop.
you dont need to pull the motor to pull the subframe. i pulled it out of my car once when the motor was still in it. i pulled it out fixed the problem i had and put it back in in about 6 hours.
Originally posted by rustyQuote:
Originally Posted by rusty
I have a full custom belt and routing right now. Removed the a/c and power steering on my lx. I am in the process of making a custom alternator bracket to delete one idler pulley and tensioner. The belt will go straight from the crank to the alternator. In the process I will install a new 50 p.
Originally posted by elscotto80So you are not going to run the water pump? Sounds like a great idea to me...Last edited by elscotto80; 05-18-2006, 08:31 PM.BP-05 Turbo-Sold
2004 MK4 AWP Jetta GLI
Mine is a 1.9, runs off the timing belt. When I had my gt, all I ran was water pump and alternator. Much easier to delete power steering and a/c on that. Just take the belt off and rip everything out. 1.9 and spi is a lot different! You have to creat your own routings depending on the accessory(s) removed. All my accessories are removed, started another exterior project so I haven't finished my bracket yet.97 protege dx few mods
94 escort lx heavily modded
