pressure loss
    hrmm i suppose i'll just see what happens.
      i had the same problem when i chage 2 stander
      GOD INVENTED TURBO LAG TO GIVE THE V8 A CHANCE!!!!!
      AND
      THE DEVIL INVENTED THE ''ANTILAG'' TO SHOW THEM NO MERSEY!!!!
        my mecanic faund the problem ??
        AND
          just take a bolt longer then the stick thets in the sleve and cut the bolt a littel longer and thet will make up for the lost of pressure
          AND
            i dont know it sound stupid but it work's
            AND
              are you implying a longer slave cylinder pushrod???
              If so i already have one.
                Ok, sounds like a good idea, but A: Don't you have to roundover the end and put the nipple on so it stays in the arm? and B: Don't you run the risk of pushing the throwout bearing off of the shaft it rides on? and C: Am I able to use the Synthetic DOT 4 after using regular brake fluid, (ie..Does it cause any leaking?).
                This is my ride: http://www.cardomain.com/ride/403088
                  if you extend the pushrod properly & grind it accordingly to fit in the slave cylinder piston you won't have issues, I know jack about dot4 synthetic.
                    What did you use to make yours?, and how much longer than stock?
                    I was hoping rusty would clue us in on the DOT 4.
                    Using synthetic does seem like a better idea, but like you said I don't want to have issues after converting to it.
                      i cut 2 pushrods welded them together & ground it down to my liking.
                        Originally posted by bpt323
                        Does synthetic DOT 4 pass by the seals if you've previously run regular non-synthetic & change or what?? I don't want to replace my calipers all over again.
                        It doesn't in my car.
                        I just use what we buy by the gallon at work....it's free for me.
                        Off the top of my head, I'm pretty sure it's Castrol Synthenic that exceeds Dot 3 and 4 ratings.
                          Cool, sounds like it's time for another well deserved upgrade.
                            As long as you are not converting to dot 5, using dot 4 sythetic you don't have to change any parts out. I would just recommend bleed the old fluid out.
                            97 protege dx few mods
                            94 escort lx heavily modded
                              Are there going to be any leaks going from regular fluid to synthetic?
                                Right.
                                Dot 3 and DOT 4 are compatible. DOT 5 is silicone based.
                                You shouldn't have any leaks when converting to synthetic.
