My Escort LX BPTed
    ehhhh....
    the NA computer runs too much timing advance at high rpm in boost, which can melt pistons and bend rods. not to mention someone also dynoed with it and found that it also tended to lean out at high rpms.... it runs wicked rich during cruise though so your gas mileage sucks.
    your best bet is to get a GTX ecu for like $200.
      Originally posted by therieldeal View Post
      ehhhh....
      The timing part I can agree with. GTX ecu i dont like due to the low rev limiter in 1st gear. And fuel cut issues.
      1990 Protege 4wd: BP05 forged internals, Mild ported head, GTR intake manifold, Gates racing timing belt, GTX transmission, Stage 3 clutch, 60trim T-3 turbo, Custom down pipe,3" Stainles exhaust, , Walbro fuel pump, RB-Performance fmic kit, HKS bov, Aurfa coilovers, F&R drilled slotted rotors, 16" BBS wrapped with Advan Novea tires, EDM glass headlights with HID's, Familia front and rear bumpers.
      Boosted 1990 4WD
      http://www.wihandyman.com/forum/showthread.php?t=32462
          rev limiter? all me gears have the same rev limits.....
          Anyway, my first gear spins too much so I need to shift in second anyway
          its not 300 rpm that will do a difference
            Quotes from the link:
            The problem is that there is noticeable power loss. With the NA ecu I can light up the tires in 3rd, can't with the GTX ecu.
            Conclusions - the NA runs very rich while cruising and leans out dangerously at high RPMS. It also has significantly more power, presumably from more aggressive timing.
            The GTX gets much better gas mileage and is safer for your engine because it has a proper A/F curve.
            Boosted 1990 4WD
              bp26ecu $150 buy it now price
              Boosted 1990 4WD
