1996 Wagon -BP Swap/build
    Well got my ass handed to me, the KIA bolts don't fit so I just ordered arp's
    1988 Mustang LX hatchback *in pieces*
    1991 Ford Escort hatchback mtx *scrapped*
    1991 Ford Escort LX Wagon atx *SOLD!*
    1993 Ford Escort GT mtx *in pieces*
    1996 Ford Escort LX Wagon mtx *rebuilding*
    1997 Taurus SHO *in pieces*
    2000 Contour SVT *mothballed*
    2000 Buick Century Custom *wrecked in Junked*
    2002 Ford Escort ZX2 mtx *SOLD!!!(THANK GAWD I HATED THAT DAMN THING WIH EVERY FIBER OF MY BEING)*
      Still waiting on ARP's Click image for larger version
ID:	1237835Click image for larger version
ID:	1237836Click image for larger version
ID:	1237837Click image for larger version
ID:	1237838Click image for larger version
ID:	1237839Click image for larger version
ID:	1237840Click image for larger version
Name:	Mazda BP ARP had studs installed.jpg
ID:	1237854Click image for larger version
Name:	Mazda BP ARP head studs and gasket installed exhaust side.jpg
ID:	1237855Click image for larger version
Name:	Mazda BP ARP head studs and gasket installed.jpg
ID:	1237856Click image for larger version
Name:	Mazda BP ARP head studs installed intake side.jpg
ID:	1237857Click image for larger version
Name:	Mazda BP cylinder head installed front side 2.jpg
ID:	1237858Click image for larger version
Name:	Mazda BP cylinder head installed front side.jpg
ID:	1237859Click image for larger version
Name:	Mazda BP cylinder head installed Intake side.jpg
ID:	1237860Click image for larger version
Name:	Pacesetter header primed.jpg
          mmmm shiny!
            Just thought I would point out that BP head bolts are not TTY bolts. I dont really know why everyone thinks that. If they were TTY bolts it would be easy to find them, in addition to other reasons.
            FS Forged H beam rods
            awaiting test fit
            Aluminum CAS/Distributor caps
            BP oil jet eliminators
            EV14 fuel rail spacers
            More stuff coming soon.......
              Only reason why I assumed they were TTY, is because every repair manual says to replace, and I am unable to definitively find out otherwise. What makes you say they aren't TTY?
                If your looking at a chilton or haynes manual then I wouldnt be surprised since not all of their info is always accurate. A few reasons I say they are not TTY.
                1: My FSM doesnt say anything about replacement.
                2: They cant be found anywhere but the dealer, and considering how long the BP has been around and how many people rebuild them, they should be easily obtainable.
                3: And the biggest reason of all- the torque spec: If the spec is only given as a torque value regardless of how many steps its a standard head bolt. If the spec calls for a torque value + an angle then they are TTY bolts. Since the bolts have to stretch a certain amount to work correctly they have to use an angle value. If you only used a torque spec for them, some would be correct, some not enough or some too much due to the bolt/thread friction giving a false sense of being tight. Hope that makes sense.
                awaiting test fit
                  Well my Chilton, Haynes, 1993 and 1996 Ford FSM all explicitly state not to reuse the hardware. I did find it odd that the installation only involved a torque spec. The instructions for all the other engines I have done did involve a torque spec and angle. Another thing I noticed is that the FSM specs the torque at 60 ft lbs and the ARP's I bought called for 80 ft lbs. I figured worst case scenario is I would end up with expensive ARP's. I wouldn't be surprised at all if you were right 300zxrb26dett
                    The ARP studs will achieve the same thing as a TTY bolt, which is even clamping loads and they are reusable.
                    Here is more proof for you and others: Fel-Pro says "bolt replacement recommended" and then they do not even have the bolts available at all.
                    If you switch the search to 1.9L which I know for sure are TTY bolts it says "bolt replacement required" and their head gasket kits include new bolts and they can be purchased as a set by themselves under a different part number. The 1.9L also has a torque spec of 40ft lbs, 90 degrees and 90 degrees IIRC.
                    awaiting test fit
                      us old guru's just know that stuff
                        Yeah I don't doubt that, I have saved myself a lot of money over the years by consulting enthusiast's forums.
                          Rustoleum High heat paint Click image for larger version
Name:	Valve cover 1.jpg
ID:	1237878Click image for larger version
Name:	Valve cover on bed.jpg
ID:	1237879Click image for larger version
Name:	Valve cover in oven.jpg
                            I apologize for lack of updates, I had a big life change recently so I was indisposed. I just started working on the motor again yesterday so I will be posting pics soon. :D:D:D
ID:	1238459Click image for larger version
ID:	1238460Click image for larger version
ID:	1238461Click image for larger version
                                Where did you pickup the waterpump pulley?? & whats the weight comparison to OEM??
