I have just got the 91 Escort GT built by Jim Pierce back on the track with a new motor (Wisco forged pistons and Carrillo rods) and a Kaaz LSD! It runs grate but is building more heat than it should and dosen't pull to redline like it use to (only tried near the end of the day). I think my initial timing is off. What should my idle timing be set at (rpm and degrees). I only have a N.A. service manual. Thanks guys!
BPT initial timing
OEM is 10 most people typically don't go over 14 base---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
- Likes 1
