1996 MX-3 RS... soon to have MY BP! (X to 56k)
    i cant wait to see what those wheels look like, ive seen the black ones with the gold lip, i really wanna see how they look on your car
    95' mx-3 BPT GT28r
      not sure i would like my wheels to stick out that far but they look good
        i like the drag wheels!! i hope you dont spend a fortune on sanding the inside of that thing. it will perform just find the way it is. if you need the extra 20hp bump the boost and call it a day!!
        GOD INVENTED TURBO LAG TO GIVE THE V8 A CHANCE!!!!!
        AND
        THE DEVIL INVENTED THE ''ANTILAG'' TO SHOW THEM NO MERSEY!!!!
          I already have the 17" Axis Maglite's on them... I like the look. It was X-men inspired with those X rims on that RX8.
          As for sticking out that far... that's just for drag so I don't care. I've moved my tires to some Micky Thompsons... instead of the BFG's.
          Yeah I don't sand, I grind!!! But I've come to another design flaw that I did, and it's my fault and I'm an idiot. On the flange, which was originally off a header type manifold, I cut the pipes off it and then chiselled out the pipe outta the ports of the flange... BAD MISTAKE! Now the ports are too big and I now have to go back and weld in a sleeve to close up the hole. If I let the port dump into a big hole I'm gonna get reversion which will slow down the velocity of the gas and then I'll get velocity-lag.
          On a side note, I'm going back to one of my old machine shops to use the milling machine and fix the warped flanges of the turbo and wastegate... gah, I hate setting this crap up. Oh well it has to be done.
          Member of MX-3.com
          "Do it ONCE, do it RIGHT!"
            good luck man. think there has to be much machined off the flange?
            JACK.
              Just when I thought things were going good on the turbo install...
              ... I drained my tranny oil cause I wanted to try something different cause it kept grinding gears from 1st to 2nd and this is what I find... DAMNIT CRAP!
              I dunno what I'm gonna do, I guess I'm gonna have to tear down the transmission... do I change all the gears and go for some billet ones or something stronger or what? I've got my MSP LSD in there... so I don't really wanna go and try fab up something to fit the MR2 just yet.
              Well, I've just got to run the lines from the turbo... but now I can't use rubber hose at a certain part cause it's way too close to the manifold at one point and too close at the turbine housing. So I'm trying to source out some mild steel tubing.
              Member of MX-3.com
                thats a super nice build, youve got so much time into it.. i cant believe everything youve actually done to this thing.... and yea i just checked out every page.....lol....just wow...
                92 protege lx-
                94 protege lx-
                  M-Tuned Dual Feed Fuel Rail and Ceramic Coated Turbo Manifold...
                  This is how I hooked up the FPR... used a street 90 degree 1/4" elbow...
                  Ceramic Coated and Radiator spacing is tight...
                  These are my turbo fittings from Earl's... Restrictor, Oil, Water...
                  MORE PICTURES...
                  Member of MX-3.com
                    that looks sweet! Tight fitting but way cool! I am excited to see it done. And as far as the tranny... 2nd gear went out in my old tranny too.... But I would do a mr2 upgrade But I don't know what I am talking about... I didn't even know it would fit!
                    Mexican: "You wanna race for titles?"
                    Mormon: "lol, no, I don't want your car."
                      Very nice to see that manny coated Jon! It's all looking very sweet. How close is the turbo to the hood? It looks very tight on the radiator side.
                        i like it, i would have gone with an aftermarket firewall FPR tho, im sure blox or somebody makes one fairly cheap
                        95' mx-3 BPT GT28r
                          Booo for no room! Yay for power!
                            Mmmhmmm...
                            Who's hiding?!
                            Oh and some new fan cause the other one ain't gonna fit with no room... might have to make it a pusher rather than a puller.
                            More Pictures...
                            Member of MX-3.com
                              shades i see your using a dohc fast idle valve switch to a sohc valve both coolant lines face down
                              just looks a little cramped
                                Yeah I know, it's a tight fit especially with that fat fuel rail in there now.
                                I have to hit the junkyard and go get a SOHC one in the future... but right now I'm just trying to get my turbo on the road. I'm close, just gotta bolt everything up now that I'm done my water/oil lines which I'll be snapping some pictures of soon.
                                Side note: Also in the works is a Black MX-3 SE... excited!
                                Member of MX-3.com
