Trigger wheel= no launch control/flat shift
1996 MX-3 RS... soon to have MY BP! (X to 56k)
wow... i was interested in those i didn't realize it was $800, what all are the advantages of this?In the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
The ProjectMx build thread
MyCardomain[/SIZE]
Hey, that looks very familiar, lol. Nice work.
Originally posted by mx-3_4evr View PostTrigger wheel= no launch control/flat shiftIn the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
Originally posted by projectmx View Postthat doesn't sound like an advantage to installing this
antonio, explain why you can't have launch control/flat shift with a trigger wheel???---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Huh?... how does a trigger wheel take out my launch and flat shift?
Ok it's $600ish for the dampener... and the rest is for the trigger wheel plus machining it down to fit.
Yeah thanks again for the pictures Ferdi!
I got some CAS and gonna try and swap from using my distributor to some coil packs and go.
Member of MX-3.com
"Do it ONCE, do it RIGHT!"
Launch control and spark cut functions don't work with EDIS, but you still can have a trigger wheel and spark cut options with MS1 w/o EDIS.
Btw with MS1 a trigger wheel will not give you any more resolution since it will still be setup as a 4 point decoder wheel that just happens to have extra teeth"Discontent is the first necessity of progress."
I run MS2... gonna try the MS2 extra code again sometime to see if they've fixed the bug.
SOOOOOOOOOOOOOOOOOOO...
I now have version 2 of my car, yes version 2.
I had to yank the engine and tranny... take off the tranny, THAT STILL RAN, cause it was spitting out teeth. Pictures to follow when I get time to open it. I now have a Kia rebuilt tranny with that lovely MFactory LSD, we'll see how that differs from the MS LSD I had in there before.
Second thing that was upgraded was the UR underdrive pulley is now gone... I now have the big money ATI super damper. What a bitch to put on since it's a press fit pulley instead of a slip fit. But it's on and I can hear the engine running a little smoother, and not all choppy... who cares that it's heavier.
Member of MX-3.com
pictures!!! & what bug with MS2 are you talking about??---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
nice glad to hear she's running smooth !-Jack
She's been sleeping for over a year now... time to wake her up and get her through Aircare so I can drive her again.
Member of MX-3.com
