hes talking about the engine support member, different names for the same thing. what you are reffering to as the crossmember is more often reffered to as the subframe or k-frame.
-jon
rite.. the subframe... i wanted to know if that mount is going to be in the same place in the rs model with the I4 engine, as in the gs model,
because i have a rs and the v6 engine and i want to know if the swap will work?
yeah the subframe (in the manual called crossmember) is the same as far as engine mounting goes... not sure about the engine support member cause i havne't used my v6 one yet but it looks exactly like my I4 one
In the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
the engine support member needs to be changed, i think but i cant remember that the v6 linkage doesnt fit around/thru the 4cyl member. BUt its been awhile since ive seen both sode by side.
