modified front brakes
    ok let me rephrase that.. i'd like to be able to get a kit for under a grand and i'd like to find a 2 pot kit i think CS is 4 pot
    In the Garage
    Black 93 MX-3 GS
    Bp powered
    GTR Drive Train
    The ProjectMx build thread
    MyCardomain[/SIZE]
      These are 4 pot also. I am using the same ones as well. Theres a two pot factory caliper mod somewhere on this site....
      hello 4g63 nice to meet you
        TaDA! http://www.wihandyman.com/forum/showthread.php?t=34040
          Unless you have the skills and tools to modify a cheaper kit or buy parts you won't find anyone doing you any favors and you will have to pay market value.
            Originally posted by jaydog View Post
            Pics of the inside wheel.
            So, the top caliper bolt stays stock and only a bracket is needed for the bottom bolt?
            --Ferdi
              Yes. The top edge of the knuckle did have to be rounded off, but thats it.
                Do you have a CAD model of the bracket you made for the lower caliper bolt?
                  is it just me or is that caliper upside down?? (bleeder is at the bottom)
                    Look at the pics in the first post, there seem to be bleeders in every corner.
                    --Ferdi
                      ahhh okay, good call.
                        So what strength metal should be used for the spacer bracket?
                        Beater=/= Sleeper
                          I was gonna ask the same question... air sinks to the bottom to bleed? Haha...
                          Member of MX-3.com
                          "Do it ONCE, do it RIGHT!"
                            Well, one bleeder per piston it seems.
                              The beeders are at all cornors because the calipers can go on either side. Theres no left or right. Only the two top bleeders need to be bleed.
                                What's the part number of the Racing Brake rotor? Is it for a Miata? They sell different versions with different offsets...
                                Also, what's the part number of the Wilwood caliper?
                                --Ferdi
