hey what did you find out about the shifter linkage? did you need the whole shifter assembly or did you just need that one rod?
Need some help with axels sohc F-series swapped for G-series
Well I just swapped the entire unit. The Protege's shifter was different, and the actuall shifter(where the knob screws too) was taller. It fixed my linkage problems and is better than ever. I got the welder I ordered a few days ago, and welded the carrier bearing to the block. Drove it today several times with the G-series and she is awesome. No more grinds, and disapearing gears. The pilot bearing was installed incorrectly in the clutch replacement before I bout the mx-3(in the f-series) it's toast I opened it up. Anyway I think the whole linkage needs to be swapped as both pieces were different in a measurement/bend comparison.
Hopefully others can learn a little for this.
for a MX-3 1.6 sohc swapping g-series from protege or escort GT with 1.8 dohc you need the 3 mounts for the trans(not sure if all are needed but I used them all and worked great), axels(passenger side carrier bearing needs to be modified it won't bolt up it's off just a bit, can drill it out and bolt or... like I did weld it to the block with several spot welds) , you need Clutch kit for the vehicle your g-series came from, the flywheel, and the transmission, you also need the shifter linkages, and depending on years you get the trans from some of them have different spedometer/trans filling areas so check this out before hand.
Thanks everyone for your help.1992 MX-3 1.6L SOHC since 4/10/08
1987 Supra Turbo 5spd. 57trim CT-26 15PSI 305rwhp 315rwtq
Also have 1990 Protege LX black exterior, gray/black interior complete car other than I have removed the tranny for my mx-3 and will be hanging on to the low mileage BP motor unless a decent offer came along. Anyway I will part anything esle from car out just PM me
Originally posted by nerd racing View Posthey what did you find out about the shifter linkage? did you need the whole shifter assembly or did you just need that one rod?1992 MX-3 1.6L SOHC since 4/10/08
