Originally posted by j.sher350
View Post
MX-3_4evr's N/A build part 2!
i dont think were gonna need to worry about the pulley sizes. if ya think about it.....its really not gonna be a huge deal.
--kinda forgot to get the dimensions, after the alum pulleys.... had some big 'distractions'Last edited by j.sher350; 01-20-2010, 06:25 PM.92 Pro - Daily Beater and project- current frankenstein
Cams are very very reliant on your other mods, so advertised HP is nothing more than a billy mase oxyclean infomercial"Discontent is the first necessity of progress."
Hey, I emailed the camshaft ebay seller to see if he has a dyno graph, and this is his reply:
we do not currently have a dyno graph. These
camshafts are made to be run with the your stock
valvetrain. These cams are good for 5+ whp from
about 3K up with your stock setup, with headers,
an intake, etc. we have seen more than 10 hp to
the wheels.
you will be very happy with your car after
installing the cams.
Hope to hear from you soon
Guysinashed.
yeah that is supposed to be like it. thats the back side of the pulley. its to keep the specs. w/p pulley and alt pulley are virtually the same specs except for diameter. so i basically just steppped up the diameter for the w/p pulley and added a few design elements since its a 3 bolt pattern.
refer to the second pic of the alt pulley. the boss (nub sticking out) is the same feature as the '3 point wing nut' on the back side of the w/p pulley. the boss is just a lil different but serves the same purpose.
see what i mean?92 Pro - Daily Beater and project- current frankenstein
I don't think you know what I'm trying to say. The way you are holding the stock water pump pulley is how it's installed on the engine. meaning that the pulley's offset helps it go closer to the engine. In your design, the water pump pulley's design, helps it stick out. So I'm talking about the offset. Look at the water pump pulley on your car and see what i mean
